What do you think this is worth
Hey guys i'm trying to see what my motor is worth in value. I may be selling it to pay some bills I want it to be far but still good value for me. If this is the wrong fourm i'm sorry for the inconvenience. Thanks for your time guys.
NO SMOKE
GREAT COMPRESSION (9:8:1) with the block and head combination
good T-belt/Water pump
good plugs/wires
New intake/TB gasket
good cap/rotor
USDM B18C1 block
JDM b16a1 head
NEW blox intake manifold
NEW 65mm TB
GSR cams
AEBS head studs
OEM headgasket
OEM ITR oil pump
stock flywheel
ACT pressure plate stock disc.
full mounts
shift linkage
and inter. shaft with axles.
chipped ECU
No exhaust manifold
No tranny
No wiring harness
Pretty much just need the above listed and it will fire right up I GUARANTEE it will fire and run with out any problems on the motors part that is
Thanks again guys i can get pics and awnser any questions.
Kevron
Modified by KevronsEG at 6:31 PM 2/11/2007
Modified by KevronsEG at 11:49 PM 2/14/2007
NO SMOKE
good plugs/wires
good cap/rotor
USDM B18C1 block
JDM b16a1 head
NEW 65mm TB
GSR cams
AEBS head studs
OEM headgasket
OEM ITR oil pump
stock flywheel
full mounts
shift linkage
chipped ECU
No exhaust manifold
No tranny
No wiring harness
Kevron
Re: What do you think this is worth (KevronsEG)
its worth more. is a complete B swap into eg minus Tranny,wiring harness worth way more than 1k-1500
Are you serious? You have no tranny and no wiring harness. It is no where near a complete swap seeing as your missing two very big parts of a swap.
Re: What do you think this is worth (boostedblkef)
the title says Re: What do you think this is worth (KevronsEG)
that is what i think its worth
i love honda tech you ask what people would pay and then when someone tells you you argue if you think its worth more put it for sale and find the hell out but good luck getting more than 1500 for it
Ok so lets price this out (all LOW END PRICES)
USDM B18C1 block- 650
JDM b16a1 head -400
NEW blox intake manifold-150
NEW 65mm TB-130
GSR cams-free
AEBS head studs-100
OEM headgasket-50
OEM ITR oil pump-100
stock flywheel-free
ACT clutch -250
full mounts -100
shift linkage-50
and inter. shaft with axles.-200
chipped ECU-130
ALL MAINTENCE DONE TO MOTOR 300
total 2,610 take 20% just for you guys. Thats still 2,000 right there and you dont have to do a thing to it. just drop and start. so no TIME cost in there. I dont think you have really thought of all the cost involved. There is a lot of misc. things that have been done. the manifodl and TB are all NEW never used. they are not bare have all sensors, injectors, furl rail its all COMPLETE. all new gaskets. and all those prices are just low end prices. Full gsr swaps go for 23-2800 with NO MAINTENCE DONE. and NO aftermarkets parts and its all Put together. I'm not fighting i'm Stating that i THINK its worth more just like YOU thought is not.
Everybody uses they own wire harness.
trans go for 600 all day. I was thinking 2000 witch is a steal
JDM b16a1 head -400
NEW 65mm TB-130
GSR cams-free
AEBS head studs-100
OEM headgasket-50
stock flywheel-free
ACT clutch -250
full mounts -100
shift linkage-50
chipped ECU-130
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevronsEG »</TD></TR><TR><TD CLASS="quote"> I was thinking 2000 witch is a steal</TD></TR></TABLE>
ok so then if you knew a price that you wanted for it why is this posted in hybrid ?
post in the f.s forum and stop wasting space in here
I dont know a price, thats why i posted. That is the price i thoughtit may be worth but didnt want to be to high and or to low. HT people are so angry, is unreal haha nobody can be nice on HT. sorry for wasting YOUR space and time. Thats why you keep reading and posting.
have GREAT DAY
have GREAT DAY
I got my complete JDM B16a Motor, Trans, ECU, Hondata s200, Jun Cam gears, Urethane bushings, axles, JDM ITR Header, AEM Intake, Sppon grounding kit, all very well maintained for $3K and that was about 3 years ago. I'm not an expert, but I'm pretty sure that the prices for B-series motors are probably a bit cheaper now. Everyone wants the K series now. I said $1500 obo because that price seemed fair to me, I'm not trying to make you feel bad. Find some kid that doesn't know much and You prob. could get $2K for it. Rule of thumb, expect to get about half of what you paid new for used parts.
Re: What do you think this is worth (fitfreak3)
Down here in tampa you can get a COMPLETE gsr for 2 grand. A motor with no wire harness and tranny is worth less than $1500 imo.
Re: What do you think this is worth (DC2jdmIntegra)
your asking the same Q. as the guy above and i have the same answer as i did then.
