Stock H22A4 or Built D16Y8? Need you inputs!
I have a 97 Civic EX with no motor, sitting in garage is the stock D16Y8 and rebuilt stock H22A4 with all the hardware for the swap; except the ECU which I'm not certain what to use, ODB1 or 2 and what wiring harness to use(I believe it's my stock EK wiring harness, I know I have to extend a couple wires, please correct me if I'm wrong or give me some guidance or link for reference.------- What will you do? My options are: Slap the stock H22, I know it will be a headache with the wiring or forge the D16 towards 11:1 comp ratio. Note that both options will be using wet nitrous, 100 shot for stock H22 and about 125 to 150 for the D16. Need your inputs, I'm indecisive!
Re: Stock H22A4 or Built D16Y8? Need you inputs! (LudaChris)
I would just throw the h22 in it, if you have everything for the swap why not?.If you decide to go with the h22 just get a p28 and chip it!!!.(now about the wiring there's lot of info in here just search!). But then again its your car do what you think its best and most important , your budget.
LudaChris
02-27-2007 02:32 PM
mikegeezy
03-13-2006 08:18 AM
