B18C5 / ITR motor in an EK...throttle cable?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I currently have a 97 civic coupe with a GSR swap. I'm using a GSR throttle cable and bracket that my buddy lent me. I'm pulling the swap for a 98 ITR motor, which has the throttle cable bracket attached to the ITR intake manifold.
Do I HAVE to use the ITR throttle cable, or can I run a B16 or LS throttle cable on an ITR EK?
Re: B18C5 / ITR motor in an EK...throttle cable? (boostincoupe)
You should be able to reuse it or may need only to change the throttle cable bracket.
Re: B18C5 / ITR motor in an EK...throttle cable? (BJO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BJO »</TD></TR><TR><TD CLASS="quote">You should be able to reuse it or may need only to change the throttle cable bracket.</TD></TR></TABLE>
Did you read the thread? I don't have a throttle cable, and I'm wondering if I NEED to buy an ITR throttle cable, or if a B16 or LS throttle cable would work.
The cable will work so long as the bracket is moved a bit. I had a shop ghetto fab one for me.
bleakdragonmage
02-25-2007 10:40 AM
timisyourfriend
11-12-2006 12:29 PM
