Whose all NOT running front torque mounts?
Old Feb 12, 2007 | 11:52 PM
DFW's Avatar
DFW
Default Whose all NOT running front torque mounts?
How many of you are not running torque mounts (both front, tranny and ac bracket) with your swap? Just wondering if it would be safe to run without them. Using 75a grade mounts for the other motor mounts btw.
Old Feb 13, 2007 | 06:30 AM
rudebwoy's Avatar
Default Re: Whose all NOT running front torque mounts? (DFW)
if you want the motor to hit the hood.
I ran my car without the tranny side torque mount at the track for one event, I was launching at 6000rpm, and the motor/turbo manifold ripped through the hood of my freshly painted car.
Old Feb 13, 2007 | 09:09 AM
slomofo's Avatar
GDD Member
I've got no ac mount and it works ok. I've seen a few trannies break off where the rear L bracket mounts due to a bad rear mount and lack of torque mounts, but if the rear mount was good, I doubt they would've had that problem. I guess it just depends on how you drive, if you're dropping the clutch at high rpms like the previous guy, I'd run them.
Old Feb 13, 2007 | 11:12 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (slomofo)
if u have hasports, other man mounts u should be fine.. otherwise ur hood will get hit by the motor. as the mounts are there to stop the motor from moving up and down and all around
Old Feb 13, 2007 | 11:13 AM
DFW's Avatar
DFW
Default Re: (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">if u have hasports, other man mounts u should be fine.. otherwise ur hood will get hit by the motor. as the mounts are there to stop the motor from moving up and down and all around </TD></TR></TABLE>
I'm running Innovative mounts with the 75a inserts.
Old Feb 13, 2007 | 12:24 PM
EG_H2B's Avatar
Thas the same setup thats on my friends car. Had it on there for the last year with no probs at all
Old Feb 13, 2007 | 12:41 PM
DFW's Avatar
DFW
Default Re: Whose all NOT running front torque mounts? (JohnShiwota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnShiwota &raquo;</TD></TR><TR><TD CLASS="quote">Thas the same setup thats on my friends car. Had it on there for the last year with no probs at all </TD></TR></TABLE>
What's his set up?
Old Feb 13, 2007 | 04:07 PM
EG_H2B's Avatar
95 Integra with Innovative 75A billet mounts
Old Feb 13, 2007 | 07:16 PM
EJgsr's Avatar
stock mounts with inserts and no problems yet.
Old Feb 13, 2007 | 11:59 PM
B18CivicEH2's Avatar
Default Re: Whose all NOT running front torque mounts? (EJgsr)
yea man, my car doesnt have them and my motor moves everywhere....you prob should used them or get a Motor Torque Damper to help out.......
Old Feb 14, 2007 | 01:34 AM
Richard...'s Avatar
Default Re: Whose all NOT running front torque mounts? (B18CivicEg)
if you got the aftermarket mounts all 3 like inovative or hasport you do not need the torque mounts!
Old Feb 14, 2007 | 09:11 AM
RaceCarRyne's Avatar
Default Re: Whose all NOT running front torque mounts? (richard7968)
make a solid touque mount.. the less your motor moves the quicker your ets will be
Old Feb 14, 2007 | 09:57 AM
goldegg's Avatar
I have Avid mounts with no ac mount and its fine.
Old Feb 14, 2007 | 10:50 AM
DFW's Avatar
DFW
Default Re: (goldegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldegg &raquo;</TD></TR><TR><TD CLASS="quote">I have Avid mounts with no ac mount and its fine.</TD></TR></TABLE>
Still running tranny side tho?
Old Feb 14, 2007 | 02:03 PM
goldegg's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">
Still running tranny side tho?</TD></TR></TABLE>
Ya, I don't trust removing the tranny side, and I would rather have the stiffer motor than loss of 5 lbs personally.
Old Feb 14, 2007 | 03:35 PM
7808's Avatar
my tranny side is hanging doesnt bolt up to my ls trans
Old Mar 23, 2007 | 03:14 PM
DFW's Avatar
DFW
Default Re: (7808)
ribal_gh
10
Nov 20, 2012 11:58 AM
fromthesun_93
Mar 23, 2012 11:20 AM
97grnrs
Nov 20, 2008 08:46 PM
whoneedzvtec
Nov 21, 2007 04:13 AM
Boner_Ben
Welding / Fabrication
Sep 29, 2007 02:04 PM
