axle problem!!!!!this is aggrivating
Old Feb 24, 2007 | 04:59 PM
jcfreibert's Avatar
Default axle problem!!!!!this is aggrivating
ok here's the situation....
92 cx hatchback
b16a swap
94 del sol tranny/w opm autosport lsd
92 integra halfshaft
here's my problem....changed the axle seal last week now the pass. side axle won't stay
in the tranny...i 've gotten 3 new axles for a 94 integra and they all do the smae thing....i've opened up all the clips on every one....and still the same thing....when it goes in, the inner joint is right on the axle seal so i don't see how it can go in anymore
,but it's like the clip is seating enough for me not to be able to pull it out by hand but when it gets moving it works its way out again...before i changed the seal it worked perfect...but it almost seems like the axle is a little short...there's a little stress on the inner joint but it kinda looks normal.....i'm all out of ideas....i've searched on every forum i can find for answers to this problem if any of you guys have ideas throw them my way cuz this is rediculous.....i 've done quite a few of these and never had a problem like this
-thnx
Old Feb 25, 2007 | 12:24 PM
egsleepercivic's Avatar
to run a 94 axles I believe you need a 94-01 halfshaft
Old Feb 26, 2007 | 02:00 PM
WhiteSol's Avatar
Default Re: axle problem!!!!!this is aggrivating (jcfreibert)
Have you used this type of LSD before? If the spline (trans side) seems too short, perhaps try a hybrid axle using a 90+ accord inner spline cup and bearings.
edit:
I had never heard of them before so I looked them up..
"The OPM limited-slip is a patented clutch-type custom made limited-slip differential. We start with a stock diff and remove all the gears and shafts to inspect and clean them. Then machining of the case is performed and the clutch packs are fit. The diff is then re-assembled and a spring block is pressed between the spider gears to put pressure on the side gears."
Sounds sketchy
Modified by WhiteSol at 3:10 PM 2/26/2007
Old Feb 26, 2007 | 02:05 PM
high_revs's Avatar
u sure you have the right halfshaft?
Old Feb 26, 2007 | 03:59 PM
jcfreibert's Avatar
Default Re: (h2b_eg8)
just made autozone order me another axle.....this time the one i got from them was about an inch longer....so hopefully this is where my problem is
Old Feb 26, 2007 | 06:28 PM
just so you know autozone axles are ****, the used oem axles I got with my swap last 65k+, I have gone through 3 sets of the AZ axles in the last 20k , one axles didn't even last a week, thats why they have a lifetime warranty.
if you use AZ axles you will be good at changing them quick...lol
what part #'s are you using from AZ, I use #8000 and #8063
good luck
Old Feb 26, 2007 | 07:04 PM
jcfreibert's Avatar
Default Re: (egsleepercivic)
pass is #8000....but it took three to get the right one
Old Feb 26, 2007 | 07:30 PM
high_revs's Avatar
people f*ck around with those axles, buy them and the core they put in there is off another car and thats what you end up with...it sucks...go the junkyard and pull off an axle and have that same axle rebuilt, prob your best bet....or buy a new one from honda
Old Feb 27, 2007 | 03:48 AM
jcfreibert's Avatar
so far so good.... i drove the car around last nite and no problems yet...but i guess while working in the dark i didn't realize that i pushed the axle seal in a little so now i have to pull it back out
Old Feb 27, 2007 | 03:54 AM
high_revs's Avatar
Default Re: (jcfreibert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcfreibert &raquo;</TD></TR><TR><TD CLASS="quote">so far so good.... i drove the car around last nite and no problems yet...but i guess while working in the dark i didn't realize that i pushed the axle seal in a little so now i have to pull it back out</TD></TR></TABLE>
always somethingg gotta be stupid lol
Old Feb 28, 2007 | 03:35 AM
jcfreibert's Avatar
ok so the axle seems to be the right one....but the inner joint still tries to work its way out still.....how far open can i stretch that c clip before it doesn't function properly.....it seem like its in there,but i know it should lock in there better than that
Old Feb 28, 2007 | 06:03 AM
high_revs's Avatar
maybe there is an issue with your halfshaft???
Old Feb 28, 2007 | 12:56 PM
jcfreibert's Avatar
from a 92' integra......don't forget im on the pass. side too.
Old Feb 28, 2007 | 03:26 PM
high_revs's Avatar
you need 94+ integra halfshaft
Old Feb 28, 2007 | 03:51 PM
jcfreibert's Avatar
why????? i thought either one would be ok.....this halfshaft has been on the car for almost 4yrs
Old Feb 28, 2007 | 04:23 PM
high_revs's Avatar
92 integra halfshaft is female
94+ integra halfshaft is male
so if you have 92 halfshaft that means ur prob using that axle which is shorter then 94+ integra hence your issue.
Old Feb 28, 2007 | 05:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">92 integra halfshaft is female
so if you have 92 halfshaft that means ur prob using that axle which is shorter then 94+ integra hence your issue.</TD></TR></TABLE>
I know i mentioned something about halfshaft earlier in this thread, but that was before I realized he was working on the pass side, so the halfshaft would not effect the pass side axle
Old Feb 28, 2007 | 05:27 PM
high_revs's Avatar
ohhh...i thought it was the driver side the whole time....shoot me
Old Mar 8, 2007 | 04:21 PM
jcfreibert's Avatar
damn....still @ it.....can someone post some pics of how far their axle sits in the tranny.....i swear the clip is almost there but i just killed an axle beating it in there....i don't understand what could keep the clip from seating properly.....i need help guys
Old Mar 21, 2007 | 06:31 PM
jcfreibert's Avatar
up
Old Apr 2, 2007 | 11:05 PM
pompom's Avatar
how much spline is on you axle compared to the transaxle?
Old Apr 3, 2007 | 01:43 PM
WhiteSol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcfreibert &raquo;</TD></TR><TR><TD CLASS="quote">damn....still @ it.....can someone post some pics of how far their axle sits in the tranny.....i swear the clip is almost there but i just killed an axle beating it in there....i don't understand what could keep the clip from seating properly.....i need help guys</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteSol &raquo;</TD></TR><TR><TD CLASS="quote"> If the spline (trans side) seems too short, perhaps try a hybrid axle using a 90+ accord inner spline cup and bearings. [/i]</TD></TR></TABLE>
The spline is a bit longer on the accord axle, it may work for you. I had a similar problem with my CRV transmission, and the hybrid axle worked perfectly.
RanCRX
Dec 28, 2009 03:03 PM
jcfreibert
Feb 28, 2007 09:22 AM
jcfreibert
Feb 25, 2007 03:16 PM
turbotime
May 28, 2006 10:08 AM
crx8psi
Jun 16, 2004 04:39 AM
