CRX B16, off time? Code 23 and idle prob.
Old Jun 15, 2002 | 10:44 AM
nsxmatt's Avatar
Default CRX B16, off time? Code 23 and idle prob.
B16 in a crx, has been throwing a code 9 (cly sensor) since we got it put in and it's been idling real rough with a miss (not driveable). Replaced the cly sensor which didn't help and then just got a replacement distibutor. My brother put the distributor on and when he did he had it slightly retarded unlike the previous one. Now it runs slightly better but it's still missing and idling rough. I also advanced the timing back and even more than before and then it won't even start. Also the code 9 went away and a code 23 (knock sensor) comes on after it's reved for a while.
My question which I think is what's wrong, Is the timing belt off one tooth? If so is the engine (valvetrain) still ok if we set it back? I know they are a zero tolerance motor. Also why would a engine just off the boat be off time? Any help would be gratly appreciated!!!
Old Jun 16, 2002 | 04:49 AM
nsxmatt's Avatar
Default Re: CRX B16, off time? Code 23 and idle prob. (nsxmatt)
Anyone?
Old Jun 16, 2002 | 07:35 AM
Blown90hatcH's Avatar
check your firing order?
Old Jun 16, 2002 | 05:30 PM
nsxmatt's Avatar
Default Re: CRX B16, off time? Code 23 and idle prob. (Blown90hatcH)
Checked firing order, plug wires, plugs, distributor, and wiring. We're gonna check the physical timing tuesday when we get a light.
Anyone else have any ideas?
Old Jun 16, 2002 | 06:59 PM
Check cam to crank timing. It sounds like you are either off one tooth or the firing order is wrong. Or the distributor is bad.
Old Jun 17, 2002 | 04:57 AM
nsxmatt's Avatar
That's what I said before. Distributor is not bad two have been tried and tested. Firing order is right per service manual and by looking at my motor. I'm pretty sure it's one tooth off but like I said before I wanted someone who has had this happen before to tell me their opnion on what they did or how it could have happened on a good imported motor.
Old Jun 17, 2002 | 02:18 PM
MPower332TI's Avatar
this happen to me when i installed a b17 into a ef..it ended up being the map sensor,,id check the map and also take your side engine cover and check to see if its off a tooth...if was off a tooth and u ran it it might have bent some vavles and that would cause your shitty running condition...id do a compression test on it soon also...
stopltracr
Jan 25, 2016 04:35 PM
m3kid
Jun 2, 2012 11:47 AM
itslogz
Mar 29, 2008 09:04 PM
nsxmatt
Dec 22, 2003 06:53 PM
done
Oct 8, 2002 03:37 PM
