obd2 b18b what is the diffrence to obd1 b18b
Old Jun 22, 2002 | 10:32 AM
todds94teg's Avatar
Default obd2 b18b what is the diffrence to obd1 b18b
hello I'm going to swap out my old b18b obd1 for a low milage obd2 b18b. I would like to know what i have to change and what are the diffences in the motors,trans,ecm wires,ac,power steering lines. thanks alot for your help.
Old Jun 22, 2002 | 10:52 AM
JV's Avatar
JV
Who?
Default Re: obd2 b18b what is the diffrence to obd1 b18b (todds94teg)
It's all plug and play if you use the OBDI ECU......
Old Jun 22, 2002 | 12:16 PM
todds94teg's Avatar
Default Re: obd2 b18b what is the diffrence to obd1 b18b (JV)
are you sure i've been told that you have to use obd1 distribter,injectors on the obd2 motor to use
Old Jun 22, 2002 | 06:57 PM
JV's Avatar
JV
Who?
Yes i am sure. I have done this swap (96 OBDII B18B motor w/ OBDI P75 ECU). The underhood harnesses will plug right in, as will the OBDI ECU. Hence the term Plug and Play.......
Old Jun 23, 2002 | 10:38 AM
Honda4CX-T's Avatar
What he said .....
Done several swaps with this method as well.
[Modified by Honda4CX-R, 2:39 PM 6/23/2002]
Old Jun 23, 2002 | 02:27 PM
todds94teg's Avatar
Default Re: obd2 b18b what is the diffrence to obd1 b18b (Honda4CX-R)
sweet that sounds good to me no need to swap out any parts on the motor just keep my stock ecu that so cool thanks guys
Old Jun 23, 2002 | 02:37 PM
Slopoke's Avatar
I think this needs to be clarified.
The obd2 motor is plug and play if you use the obd2 wiring harness(which will plug into your chassis harness w/ no problems)
If you are trying to use your obd1 harness, then yes, you will need to reuse your injectors, distributor, and alternator.
I just wanted to make that clear since it seems like everyone is just assuming you have the obd2 harness also.
Old Jun 23, 2002 | 06:23 PM
todds94teg's Avatar
Default Re: obd2 b18b what is the diffrence to obd1 b18b (Slopoke)
thanks that makes the most sense so far do you know if the ac lines are the same and power steering as well? thanks for the help so far
Old Jun 23, 2002 | 07:15 PM
Honda4CX-T's Avatar
Whoa buddy !!! Who is assuming here ???
OBD-2 Engine harness will plug into OBD-1 Chassis Harness and will work taking in consideration you will be using ODB-1 ECU as well --- Hence the term "Plug-N-Play"
Old Jun 23, 2002 | 07:31 PM
Slopoke's Avatar
PLEASE REREAD MY POST!!!
The exact same thing.
Im referring to using the OBD1 engine harness(off of the OBD1 engine that he currenty has) on the OBD2 ENGINE(what he wants to switch to).
He never said he had the OBD2 engine harness. You never told him that he needed the OBD2 harness. So by telling him it was plug and play you were either ASSUMING he already had the OBD2 harness or you just dont know what your talking about.
Old Jun 24, 2002 | 12:32 PM
todds94teg's Avatar
thanks for the help guys
AdrenalineAngel
Oct 31, 2012 09:22 PM
LSReborn
Apr 8, 2007 05:25 PM
I got a honda
Jan 15, 2006 07:17 PM
VTECyoda
Oct 29, 2003 07:08 AM
GumballNA
Jul 17, 2003 12:30 AM
