Engine blue printing ? ? ? ??
Old Jun 25, 2002 | 05:36 PM
VtecApprentice's Avatar
Default Engine blue printing ? ? ? ??
Are the engine we import blue printed ? ? ? ?
how i know whether is it blue printed ? ? ? ?
After blue printing the engine can we still do modification on it ? ? ?
^_^ tHanKz wHoevEr
Old Jun 26, 2002 | 07:47 PM
Default Re: Engine blue printing ? ? ? ?? (Hardcore Civic Fan)
Soneone PlsS ? ? ? ? ?
Old Jun 26, 2002 | 08:55 PM
Kamin's Avatar
do you know what blueprinting means??
Old Jun 27, 2002 | 12:50 AM
to extend the RPM redline ? ? ? ? ?
Old Jun 27, 2002 | 10:56 AM
X2BOARD's Avatar
Heh heh heh... .nope... blueprinting is typically done while balancing. It puts all the parts of the motor in question to exacting factory tolerances and specs... It just makes the motor more reliable and smoother operation. Yes you can still mod a blueprinted engine... just don't replace the parts that were blueprinted.
X2
Old Jun 27, 2002 | 12:04 PM
Dokta's Avatar
Default Re: Engine blue printing ? ? ? ?? (X2BOARD)
when an engine is manufactured, everything is made to within certain tolerances. ie the bore to a b20 is 84mm +/- .0012mm. when an engine is blueprinted, the machine shop machines everything to a much tighter tolerance, like +/- .0002mm for example. this makes the engine much more like the original blueprints, and much more reliable since it is much closer to how the engineers designed it. the reason they dont do this at the factory is because it is unneccessary on most stock engines, and the closer the tolerances, the more expesive and difficult it is to produce the engine. Lets face it, noone would buy a civic if they cost 40,000 each. But if you are modifying your engine to do more than it was designed ( higher RPM, higher compression ratio, turbo, supercharger, etc... ) its a good idea to make sure those tolerances are as close as they can be.
Old Jun 28, 2002 | 12:51 AM
Default Re: Engine blue printing ? ? ? ?? (Dokta)
ThaNkzZ X2BOARD and Dokta for your Reply ^_^
JScott3d
Jan 15, 2008 10:55 PM
Chopaholic
Sep 4, 2007 10:46 PM
Chewy[Ek]
Apr 25, 2007 07:41 PM
em Dot
Jun 9, 2004 09:51 AM
