obd1 ecu and obd2 engine...will it work?
Old Jun 13, 2002 | 04:15 AM
Thagreybomber's Avatar
Default obd1 ecu and obd2 engine...will it work?
I've got a 96 b18c1 and a 95 ecu. If all goes well with no problems, will the engine work or run properly? What will happen if nothing is done to make the engine obd1 compliant?
Old Jun 13, 2002 | 04:23 AM
10seconds's Avatar
Honda-Tech User
Default Re: obd1 ecu and obd2 engine...will it work? (Thagreybomber)
the ecu wont even plug up to that.
steve
Old Jun 13, 2002 | 04:54 AM
oldbeefcake's Avatar
If your car is OBD I, Then it will work. If your car is OBDII, then you need an ECU jumper harness.
Old Jun 13, 2002 | 04:58 PM
Default Re: obd1 ecu and obd2 engine...will it work? (Jun)
More clairification...
My car is already OBD1, it is a 95 EX. What kinda problems will I encounter by just plugging it in and trying to run it?
TIA!
Old Jun 14, 2002 | 05:53 AM
no problems. Thats what I'm trying to say.
Old Jun 14, 2002 | 06:59 AM
Kalokohan's Avatar
New User
The ecu will work, that's actually better than getting an OBD1 to OBD11 jumper. In order to make the IAB's work, you have to reverse the polarity of the signal and change Pin A17 to A20.
Old Jun 17, 2002 | 09:17 PM
Default Re: obd1 ecu and obd2 engine...will it work? (Guardson3r3)
what is IAB? Stupid me doesn't know.
RageRage
Jun 23, 2014 10:24 AM
95 iteg
10
Jun 3, 2013 11:36 AM
hoskos
Oct 13, 2006 01:45 AM
wsiracerz
May 25, 2004 08:41 PM
