Will a B16A2 tranny fit a B16A1 ????????
Old 06-18-2002, 06:01 AM
Zeus Zore's Avatar
Default Will a B16A2 tranny fit a B16A1 ????????
will it ???
THX
Old 06-18-2002, 10:53 AM
spettinger's Avatar
Default Re: Will a B16A2 tranny fit a B16A1 ???????? (Zeus Zore)
yes, all b series transmissions work on b series motors. i see you have a 92, with a hydraulic clutch pedal, so you should use the B16A2 transmission for best results.
Old 06-18-2002, 12:42 PM
Kamin's Avatar
please dont half *** it and get a first gen b16 unless your not paying for it
you need more than just a transmission and clutch.
it WILL cost you more to do that swap than to save the money and do a second gen b16.
[Modified by KAMiN, 1:43 PM 6/18/2002]
Old 06-18-2002, 05:50 PM
Zeus Zore's Avatar
Default Re: Will a B16A2 tranny fit a B16A1 ???????? (KAMiN)
?? why ?! if i get a B16A1 with B16A2 tranny should the speedometer and so on not work !? and would the hydro not fit ??
what else would be needed !?
The B16A1 run pretty good !!
and here it is easyer 2 get the B16A1 engine
so if the B16A2 fits it should be a easy swap ??
THX
Old 06-18-2002, 07:33 PM
slywfbpsi's Avatar
you will have to get a hydro to cable kit from hasport.
Old 06-18-2002, 07:54 PM
Kamin's Avatar
Default Re: Will a B16A2 tranny fit a B16A1 ???????? (slywfbpsi)
yep or replace the clutch with a hyrdo unit
and your still gonna need axles, injectors, harness, distributor and a diffrent ecu.
total all that up and its the same price as a b16 second gen.
the first gen motors have less agresive cams too.
Old 06-18-2002, 11:48 PM
tinkerbell's Avatar
will a B16A1 tranny fit a B20B block?
i have assumed 'yes' is the answer for some time...
t..
Old 06-19-2002, 05:12 AM
Zeus Zore's Avatar
"you will have to get a hydro to cable kit from hasport." ??
why when im getting the 2gen tranny ???
and everything else is 2gen wires and ecu only thing would be the engine !!
would this not work !!???
as i said before !! it is hard 2 come by the 2gen engine !!
and i really whanna try this out !! with the B16A1...
THX for tha help !!
Old 06-19-2002, 05:35 AM
slywfbpsi's Avatar
this should answer your questions http://www.hasport.com/M92_CC.htm
Old 06-19-2002, 11:52 AM
Kamin's Avatar
THX for tha help !!
its not all transmission
its the CLUTCH
the clutch is cable operated while the newer one is hydraullic!
second gen engines are easy to find boy! where are you looking!
http://www.hondamotorsonline.com
http://www.jdmhondaparts.com
and EVERYTHING? else is second gen? injectors? distrubutor?
1PT-SICK
04-24-2006 05:50 PM
ShogunHutch
09-20-2005 12:19 PM
ITRnorway
03-10-2004 10:00 PM
Audi A4
07-07-2002 12:28 AM
wickedxbo1
11-14-2001 08:30 AM
Quick Reply: Will a B16A2 tranny fit a B16A1 ????????
