engines out of wrecked cars
Should I do anything to my engine while it is still in the wrecked car?Drain the oil?Coolant? I plan on doing the swap in a couple months.
[IMG][/IMG]
How large is the chance of internal engine damage? I looked at the engine and the battery is pushed up against the distributor.Thats about the only visible damage I can see.Do you think my mounts will be bent?I plan on swapping into an ek/eg would it even matter?
[IMG][/IMG]
Re: engines out of wrecked cars (mr.wong)
if you plan on swapping it into a ek/eg i hope you don't A/C not without cut some of the sub-frame , cause i was going to do that with my after this happened
http://typer.homeip.net:81/car/images/Accord/
r0c5t4r
03-19-2004 05:58 AM
