What parts do I need for swap??
I'll be doing an LS swap soon into my 5th gen hatch and was wondering what all parts do i need....such as what axles can i use, what shift linkage...etc...thanx
Re: What parts do I need for swap?? (95hbMatt)
You need 94+ Teg linkage, 94-95 Teg ecu (direct plug in), We were able to take a '94 Teg engine and wire harness and plug it into the 5G hatch CX wire harness where they meet at the shock tower. Everything plugged right up and we didn't have to do any wiring changes for the 1 wire 02 to the new 4 wire 02. Everything was already prewired I guess. You use the 94+ Teg intermediate shaft (back of motor) and the two 94+ Teg outer shafts. You need the 94+ Teg front tranny mount and switch over the Civic U mount that goes on the end of it. You need the 94+ Teg top tranny mount. The 94+ Teg rear metal mount bracket. You will use the Teg mount thats on the front of the block but also switch over the Civic U mount that goes on the end of it. The mount that is attached to the driver's side of the block should still be there and you will use your stock Civic mount to connect it.
Any questions?
Any questions?
getnasty
Mid-Atlantic (Sales)
12-27-2005 03:31 PM
