ITR head on b18b block...
Old Jun 13, 2002 | 11:18 AM
baonest's Avatar
Default ITR head on b18b block...
im putting an ITR head on a ls block... and i wanted to know about the ECU... i have a 95 teg now..
do i need to use an ITR ecu (which might be chipped later) or can i get a GSR ecu..
Old Jun 13, 2002 | 12:01 PM
baonest's Avatar
Default Re: ITR head on b18b block... (baonest)
Old Jun 13, 2002 | 01:04 PM
g's integ's Avatar
p28
Old Jun 13, 2002 | 02:25 PM
forcfedcivic's Avatar
Default Re: ITR head on b18b block... (g'sinteg)
if you want to use a p-28 you should get it chipped...better fuel and timing curved for the larger motor/ injectors. if using the gsr or type r ecu..plug and play...
Old Jun 13, 2002 | 03:10 PM
g's integ's Avatar
Default Re: ITR head on b18b block... (forcfedcivic)
that's what I meant, mugen or skunk dohc.
Old Jun 13, 2002 | 05:46 PM
baonest's Avatar
can i get a quick overview of the ECU #.. ex p28 is obd1... p72 is obd2.. those are the only 2 right (for honda/acura).. does the p28 not come in gsr ITR... is that why everyone used the p28 cuz they can be chipped and are better for tuning??
thanx
Old Jun 13, 2002 | 05:51 PM
g's integ's Avatar
it sort of like the ITR ECU but a obd1 version. But what I know it eats up a lot of gas. But if u tune it w/ Vafc then u'll notice.
Old Jun 13, 2002 | 05:54 PM
baonest's Avatar
with a p28 ECU... for civic Si/Ex does the type of trans matter.... can i get a auto civik Ex ECU for my 5speed ls/vtec..
thanx
Old Jun 14, 2002 | 06:57 AM
g's integ's Avatar
Must be 5 spd p28, here's what you need:
https://honda-tech.com/zerothread?id=179605
-Gil
[Modified by g'sinteg, 7:58 AM 6/14/2002]
Old Jun 14, 2002 | 05:25 PM
JV's Avatar
JV
Who?
P28 = OBDI / 92-95 D16Z6
P72 = OBDI / 94-95 B18C1
P72 = OBDII / 96-01 B18C1
P73 = OBDII / 96-99 B18C5
HTH......
Thanks for the heads up Kenji.....
[Modified by JV, 10:55 PM 6/14/2002]
Old Jun 14, 2002 | 06:53 PM
kenji's Avatar
25 Year Member
Default Re: ITR head on b18b block... (JV)
It does not have to be a 5 speed ECU. You can easily convert an auto P28 to a manual P28.
OBD2 ('96-'01) GS-R ECUs are labeled P72 and not P62.
I have chipped P28 ECUs in stock and ready to ship for $225. Email me if you are interested.
-kenji
Old Jun 14, 2002 | 07:47 PM
deez92's Avatar
Default Re: ITR head on b18b block... (kenji)
i had mine converted and it works great, thanks kenji
Old Jun 14, 2002 | 09:30 PM
baonest's Avatar
Default Re: ITR head on b18b block... (deez92)
hey kenji.. im not that interested in buying now, i just wanted some insight on the ECU's.. do u have ECU's in stock often so incase later on i would like to purchase one.
thanx
Canada96
Engine Management and Tuning
12
Nov 15, 2015 06:29 PM
vietelement
Texas -OK -LA (Sales)
May 7, 2010 03:56 PM
99TypeR_ek
Mar 18, 2007 05:44 PM
mingbling
Feb 27, 2004 10:46 AM
JKim0901
Dec 25, 2001 11:48 AM
