hybrid ys1 tranny
Old 06-18-2002, 08:32 AM
EFSiR's Avatar
Default hybrid ys1 tranny
has any one changed the 5th gear from YS1 (92-93 GSR) for a 94up GSR one? What's involved?
I'm thinking this is better than the LS, as the RPM would dropp a lot from 4th to 5th
TIA
Old 06-18-2002, 10:29 AM
Charlie Moua's Avatar
Default Re: hybrid ys1 tranny (EFSiR)
I've have heard alot of people doing that. I'm not sure but i think it's just opening up the tranny case and swithing the YS1 5th gear for an 90-93 LS gear. somebody correct me on that ... I also wanna know...
Old 06-19-2002, 02:36 PM
court's Avatar
Default Re: hybrid ys1 tranny (Charlie)
the cable gsr's and hydro gsrs have the same gear ratios, no?
Old 06-19-2002, 10:30 PM
sleeper4dr's Avatar
yeah i did this swap. consisted of the MAIN and COUNTER 5th gear from a 94+ GSR. if you have a helms then there is nothing to it. just pull the case and switch the gears. its really not difficult at all.
and court... answer is no. on the 92-93 GSR YS1 trannies, the 5th gear ratio is ~.880 while the 94+ GSR 5th is .787
BIG difference especially for freeway cruising. the 94 GSR 5th is also a good compromise between the stock 5th and the LS 5th. i had an LS 5th in my old JDM S1 tranny and i swear the shift from 4th to 5th felt more like 4th to 6th. its a BIG drop off there, but if you want low freeway revs then its a good investment.
hth
Jason
Old 06-20-2002, 08:22 AM
court's Avatar
Default Re: hey jason
did you ever find that adress?
Old 06-20-2002, 08:55 AM
EFSiR's Avatar
Default Re: hybrid ys1 tranny (sleeper4dr)
Jason,
Did you have to change any of the syncros? Or is just just the main and counter 5th gears that have to be changed?
What was your RPM dropp from 4th into 5th with LS 5th as opposed to the GSR 5th?
TIA
Charlie
Old 06-20-2002, 09:17 AM
PLEASE answer jason... I'm also waiting to know
Old 06-20-2002, 10:23 AM
court's Avatar
5th gear synchs from big spine transmissins are all the same, along with the slidedr and reverse synch
Old 06-20-2002, 12:33 PM
sleeper4dr's Avatar
Default Re: hybrid ys1 tranny (court)
what court said.... the synchros are the exact same! ALL i had to replace was the main and counter 5th gears with 94+ GSR 5th gears. thats it!
as for the rpms thing. well when i had my JDM S1 with 90-91 LS 5th, i turned just about 4400rpms at ~91mph. i remember it that way because thats what my vtec is set to with my Mugen Chipped PR3. so 70-75 would be nice and low.
i havent had the chance to try out my 94 GSR 5th yet though because i've had to pull my head back apart on my recently finished LS/Vtec rebuild.
BUT if you go to THIS SITE
http://www.autocrossing.com\cgi-bin\gearcalc.cgi AND THEN BOOKMARK IT!
you'll be set. just pick your tranny and change the 5th gear and it will tell you your rpms at 70mph as well as a few other cool things. this site gets a HUGE for the info!
and court! check your hybrid PM! i JUST found the info you needed
*(on a side note, its important to remember that a 94+ GSR 5th is ONLY going to work in a 92+ Integra tranny and NOT the 89-91 B16 cable trannies ie. Y1/S1/J1.)
Old 06-20-2002, 06:34 PM
court's Avatar
schweeet
b18_spoon
05-23-2012 09:53 PM
Propulsion
09-26-2005 07:32 PM
sir91
08-05-2004 03:59 PM
E-lude78
13
03-02-2003 08:18 PM
FSTASNTZ
03-17-2002 10:31 PM
Quick Reply: hybrid ys1 tranny
