need new rings?
Old Jun 19, 2002 | 09:49 AM
eddie1681's Avatar
New User
Default need new rings?
I just pull my B16A motor apart, do you think I should change the rings on it?
I am going to turbo the motor.
Thanks
Old Jun 19, 2002 | 03:48 PM
Aceman64's Avatar
Default Re: need new rings? (b20z)
you mean pulled it apart..as in took the pistons/rods out? or just pulled it out of the car? if you pull an engine apart and take the pistons out. NEVER use the old rings. and i never use the old gaskets either. look at the bearings and if there not scarred up or anything you can reuse them, but i recommend changing them.
Old Jun 19, 2002 | 04:03 PM
Kamin's Avatar
Default Re: need new rings? (Aceman64)
yes change rings, gaskets and bearings
while your at it, arp head studs
do it RIGHT.
Old Jun 19, 2002 | 04:06 PM
Aceman64's Avatar
Default Re: need new rings? (KAMiN)
do it RIGHT.
i just noticed you said your going turbo. yes ARP head studs and rod bolts if your using stock rods.
-Ace
GSR_hatch936
13
Jun 1, 2008 08:03 PM
OUBob
Apr 3, 2008 05:48 AM
h22a193
Nov 14, 2004 10:16 AM
Boltz
Sep 17, 2004 07:30 PM
Underground
10
Jan 29, 2003 10:48 AM
