prep work for an h22
Old Jun 18, 2002 | 04:35 AM
drkblue_civic's Avatar
Default prep work for an h22
thinking about swapping an h22 into my 1995 civic 4 door i've heard new suspension is a good idea....ne suggestions or other stuff i may want to put on to make this a great swap...thanks
Old Jul 5, 2002 | 11:15 AM
Anyotherone's Avatar
Default Re: prep work for an h22 (drkblue_civic)
Did you find anything out about doing that swap? I'm also interested in doing it...
Old Jul 5, 2002 | 11:22 AM
Jonathan_ED3's Avatar
Default Re: prep work for an h22 (Anyotherone)
stiffer springs, better shocks, and a good set of BRAKES. other than that you could go for some sway bars etc. main thing is to just get some good springs/shocks cuz the engine is ~150lbs heavier than your stock one would be, and the engine sits lower to the ground..if you don't get some stiffer springs/shocks you'll be bottoming out a lot.
NiecoJDM
Suspension & Brakes
Feb 6, 2009 02:12 AM
LwdJdmR
11
Nov 21, 2007 09:01 PM
Racinghonda8
Sep 19, 2007 05:55 PM
drkblue_civic
Jul 7, 2002 03:19 PM
gsrvx
Oct 18, 2001 10:04 AM
