IAC help please
Old Jun 15, 2002 | 09:52 PM
2080EK's Avatar
New User
Default IAC help please
ok guys my idle is going from about 700-1500 and droping and so on, BUT as soon as i unplug the IAC on the back of the manifold the idle goes perfect, 500 perfect nothing wrong. Since it is acting thisway i asume it is not a vacuum leak.
Should i replace my IAC?
Old Jun 16, 2002 | 03:41 PM
sporkcrx's Avatar
Default Re: IAC help please (2080EK)
i'm not sure on this one...but could it be a faulty IAC guys?
Old Jun 16, 2002 | 08:46 PM
95hybridcivic's Avatar
Default Re: IAC help please (spoon2)
The IAC could be faulty. If the IAC valve has 2 wires in its harness, connect the IAC directly to battery voltage with a pair of jumper wires. positive to black/yellow wire and negative to black/blue wire. the IAC should click each time the voltage is applied. if not it is faulty. NOTE do not apply voltage to valve any longer than necessary to hear the valve click. if the valve clicks then there is another plug on the back side of the engine cant remember what it goes to but try switching the plugs and that may be your problem. hope this helps
jroxz44
Apr 19, 2012 09:21 PM
JUNKIE DUCKY
Aug 24, 2007 07:21 AM
kyles1988
Jan 7, 2007 02:46 PM
loup05
Dec 18, 2006 06:26 PM
maxxd97
Nov 6, 2003 07:10 PM
