adjusting TPS
Old Jun 24, 2002 | 11:19 AM
memphiss13's Avatar
Default adjusting TPS
well my question is how do i go about adjusting the TPS. its reading voltage too high so i guess its not adjusted right, but how do i adjust it. the car is a 93 cx with jdm b16 engine swap.
Old Jun 24, 2002 | 01:00 PM
B_CRUZ!'s Avatar
Default Re: adjusting TPS (rookie2nr)
you have to notch the 2 headless screws with a dremel. remove the T/B first.
Old Jun 24, 2002 | 01:03 PM
memphiss13's Avatar
Default Re: adjusting TPS (B_Cruz)
i know this, but how do you know when it is adjusted right? do you just keep checking the voltage as you move it until its right?
Old Jun 24, 2002 | 01:45 PM
B_CRUZ!'s Avatar
yup. stick a safety pin in the middle wire of the plug. test the voltage. it should read .05 @ idle and it should rise to 4v at WOT.
Old Jun 24, 2002 | 09:33 PM
memphiss13's Avatar
ok, mine reads 5 volts all the time, so i guess it does need adjusting. it thinks its at WOT all the time.
Old Jun 25, 2002 | 04:10 AM
EE_Chris's Avatar
So then what your really saying is that 2 of the wires you measured had +5V on them, right? If this is the case, looks like your TPS took a dive.
If you only measured one wire however, you could have measured the supply voltage to the TPS, which is +5V.
Old Jun 25, 2002 | 09:44 AM
memphiss13's Avatar
Default Re: adjusting TPS (EE_Chris)
i tried all three wires actually, i have another TB laying around so i'm going to switch them out and adjust the TPS to where it should be.
rickturboteg
Jan 11, 2007 05:20 PM
iphatcrxi
Oct 5, 2006 08:49 AM
Curtis2kul
Nov 5, 2004 12:24 PM
kholmes
Oct 12, 2004 06:59 PM
drjondurst
21
Apr 9, 2003 08:37 PM
