b20 swap
Old Jun 16, 2002 | 01:51 AM
blufke's Avatar
Default b20 swap
anyone know a good place to pick up a b20z/b? i think i wanna go that way instead of b16a. i will have to put the swap together myself right, unless someone sells full swaps. how much am i looking at spending to do this? i dont live in a place where its easy to get all these parts. thanks. also, recommendations on where to get one, hondamotorsonline, nippon, any experience with them or others?
[Modified by blufke, 11:29 AM 6/16/2002]
Old Jun 16, 2002 | 10:57 AM
10seconds's Avatar
Honda-Tech User
Default Re: b20 swap (blufke)
good luck, i think im doing a CRV motor soon, but staright CRV no vtec
steve
Old Jun 16, 2002 | 11:15 AM
Charlie Moua's Avatar
Default Re: b20 swap (jdmimports79)
I would get it from hondamotorsonline, nothing but good things about steve.
get a B-series tranny and LS ecu, afc, LS of aftermarket LS intake manifold..... what kind of car is this going into?
Old Jun 16, 2002 | 12:43 PM
blufke's Avatar
Default Re: b20 swap (Charlie)
itll be going into the easiest of all cars, a 5th gen. 92 vx actually. i need to piece together the swap and i would like a gsr tranny but those are $$$ so maybe ls then. im gonna boost too so ls isnt too bad then. do you think steve at hondamotorsonline can piece me together a full swap, or send me the tranny,etc. i need places to get all the parts: shift linkage,axles,ecu,etc. what is an afc? thanks.
[Modified by blufke, 12:56 AM 6/17/2002]
Old Jun 16, 2002 | 12:46 PM
afc is sort for the Apexi s-afe or the v-afc.
thaty would be sweet if steve could pice together a complete swap for you. If he does then let us at H-T know about it.
Old Jun 16, 2002 | 07:30 PM
#417R's Avatar
I would pay the extra couple hundred for the GSR tranny. Or you could go with a b16 tranny if you were gonna stay all motor. I bought 96 GSR tranny off partstrader for $567 shipped to my door.
Old Jun 17, 2002 | 01:10 AM
blufke's Avatar
Default Re: b20 swap (b20zkid)
what rpms do you pull with your gsr at say 70,80,90 mph? happy with it? grinds, how many miles were on it when you got it? and would i use a del sol shift linkage if i used the gsr tranny in my car. im gonna turbo eventually too.
Old Jun 17, 2002 | 11:20 PM
blufke's Avatar
does it matter which b20 i get. from some people im reading that a b20b and b20z both with i/h/e make about the same power. are the c/r actually the same. i doesnt seem like they could have a .8 difference and make the same power. and i was wondering if i can use a obd1 ls ecu for any of the b20 motors and just use my harness and extend the wires and add knock if necessary.
Old Jun 18, 2002 | 11:38 AM
10seconds's Avatar
Honda-Tech User
b20b 126hp
b20z 143 hp
jdm b20b 143 hp
Old Jun 18, 2002 | 12:19 PM
blufke's Avatar
so i should either go for the jdm b20b or the usdm b20z. thanks.
Old Jun 24, 2002 | 10:53 PM
blufke's Avatar
how can i tell the difference between the jdm b20b and usdm b20b?
Old Jun 24, 2002 | 11:02 PM
tinkerbell's Avatar
good question!
ive heard that hte USDM B20B wont have a knock sensor.
anyone else?
HTH,
t..
Old Jun 25, 2002 | 12:12 AM
C1V1C's Avatar
Default Re: b20 swap (tinkerbell)
good question!
anyone else?
HTH,
t..
true.
http://hybrid2.honda-perf.org/tech/b20/b20tech.html
I think the USDM B20B will have a number after the B, ex B20B3
JDM will just be B20B.
Old Jun 25, 2002 | 12:14 AM
C1V1C's Avatar
Get the B20Z, there's too much conflicting info on whether the JDM B20B has the high comp pistons or not (some do and some don't). And also the B20Z should be in really good condition since its 99+
Old Jun 25, 2002 | 07:38 AM
blufke's Avatar
Default Re: b20 swap (C1V1C)
so then a us b20z should say b20z(some number after it?). oh, and i really dont know the answer yet, will a skunk2 mani for obd1 ls and tb from obd1 ls work fine on the b20z? and revving to just 6.2k will the skunk2 be worth it, and consider im going turbo later too.
Old Jun 28, 2002 | 01:19 PM
blufke's Avatar
but im still wondering what i will have to do with an obd1 ls ecu, my stock harness and the b20 w/ls im and tb. what will i have to get or do???
nels00n
Feb 11, 2009 07:26 AM
Knucklehead7
Nov 11, 2007 07:09 AM
REDekSI
Aug 16, 2007 04:39 PM
redDAinteg
Oct 18, 2006 10:29 AM
