will the power steering pump from a d16y8 fit the bracket on a b18c?
Re: will the power steering pump from a d16y8 fit the bracket on a b18c? (red96)
what car is the engine from? i know the civic pump wont bolt up. if its a 92-95 civic you will need an integra pump. if its a newer civic you will need a 99-00 si pump. if you look at the pressure line and the bolts and the line are in a straight line then you need an SI pump. if the bolts are straight across and the line is offset in the middle you need an integra pump.
- Ace
- Ace
MikeFeuti
03-21-2019 07:40 PM
