Sloppy shifter??????
Old Jun 17, 2002 | 08:50 PM
1st-hybrid's Avatar
Default Sloppy shifter??????
Hey guys, I know this was posted previously, but I couldn't find the thread . I have an 88 crx hf with b18c, I'm using the HCP kit with adjustable linkage, and the shifter is sloppy as hell. I can put it in first, and it has just as much play as it would in neutral.
I know someone had this problem before, just wondering what the fix was. I can go through all the gears, but it is too damn sloppy. Thanks in advance guys.
Old Jun 17, 2002 | 10:10 PM
AWD: Jeff's Avatar
Default Re: Sloppy shifter?????? (1st-hybrid)
my short shifter is likk that also. but i ended breaking my short shifter in half.
Old Jun 18, 2002 | 08:23 AM
vtec2.0's Avatar
check the linkage support bar - the one that bolts to the tranny. mine came loose and shifting was a pain...
ryan
Old Jun 18, 2002 | 07:19 PM
1st-hybrid's Avatar
Default Re: Sloppy shifter?????? (vtec2.0)
The linkage is tight, and it's on correctly, the shifter itself is just sloppy as hell. I have to find a way to fix this, because it will drive me crazy.
Old Jun 18, 2002 | 09:49 PM
keebler65's Avatar
if the HCP ones are the type that are adjustable, then i seem to recall someone putting lock-tite or whatever on the threads to keep it from moving and adjusting. i dont know if this is 100% correct but i do remember hearing something about this on this board.
Old Jun 19, 2002 | 07:35 PM
1st-hybrid's Avatar
Old Jun 20, 2002 | 10:37 PM
1st-hybrid's Avatar
Anyone?
gameknb
Jun 11, 2005 07:32 AM
starbury
Feb 15, 2005 09:58 AM
mr_wasabi
Jul 12, 2004 03:12 PM
bullseye
Mar 27, 2004 10:40 PM
Regular Series
Sep 14, 2002 10:41 AM
