obd-0 to obd-1 problems
Old Jun 24, 2002 | 10:44 PM
EGHatchy's Avatar
Default obd-0 to obd-1 problems
I've just finished following some instructions for this conversion, however I ran into a couple problems...(these are 91 CRX Si plugs and 92 Integra plugs by the way)
1)On the Crx plugs, I still have a couple wires that have not been cut to use for the conversion. They are,
-B2(dont know)
-B4(Radiator fan control)
-B5(Alternator control)
-B19(ELD)and
-C9(PA)
Any ideas to where these extra wires go? what is the B2 wire? and what exactly is "ELD" and "PA"?
2)Second problem, I have some extra wires on the 92 Integra plugs. They are,
-A10(Pressure regulator cut-off solenoid valve)
-B8(P/S Oil pressure switch) and,
-D7(Data link connector)
I dont know where these wires go either...
3)and one more thing, I noticed a lot of the wires were the same color, what IF I accidently mixed them up, what would happen?
Any help would be great, thanks.
Old Jun 25, 2002 | 12:54 AM
Giuseppe's Avatar
Default Re: obd-0 to obd-1 problems (EGHatchy)
-B2(dont know)
-B19(ELD)and
-C9(PA)
Tandem valve control solenoid B2.....
Radiator fan control B4 (goes to A12)
Alternator control B5 .....(goes to....A16)
ELD B19 Electric Load detector....goes to D10
PA C9 (etc etc look at http://www.hasport.com and compare the schematics
hth
Old Jun 25, 2002 | 11:32 AM
EGHatchy's Avatar
Default Re: obd-0 to obd-1 problems (Giuseppe)
thanks for the info! I'll try it out later...
Old Jun 25, 2002 | 12:09 PM
EGHatchy's Avatar
ok...I looked at all my diagrams and plugs...
there arent any wires for A12, A16, and D10 on the LS plug. Do I just add them in there or somthin?
cherroneballs
Jun 1, 2010 07:30 AM
hatchback_al
13
Nov 29, 2004 04:19 AM
lsvtecrx
17
Oct 19, 2002 04:18 PM
