B18A1 into a 91 civic 4 door
Anyone have any info on this swap? Has anyone done this swap WITHOUT using aftermarket mounts such as Hasport or Placeracing mounts? Also which shift linkage do I use? I know that can use one that just has to be modified. I need this info A.S.A.P. My friend has this all torn apart and needs it going soon. Also the car has a ZC in it right now so what else needs to be modified to get going? Thanks everyone.
Re: B18A1 into a 91 civic 4 door (Azdrag)
you will have to get an aftermarket mount kit. HCP makes a kit that comes with adjustable shift linkage for $375 from http://www.jdmshit.com</a>. Good kit. Since he already has a ZC, he has already been converted from DPFI to MPFI. To run a b18 there are three wires that need to be added (knock sensor, o2 sensor, oil pressure sensor). Hasport makes a wire harness for these four wires for $75 (www.hasport.com) For B18 you will also have to get 90-93 integra axles and throttle cable and some different radiator hoses. A lot of good info at <A HREF="http://www.hasport.com" TARGET="_blank">http://www.hasport.com. Hope this helps.
[Modified by red civic standard, 10:11 AM 6/17/2002]
you will have to get an aftermarket mount kit. HCP makes a kit that comes with adjustable shift linkage for $375 from http://www.jdmshit.com. Good kit. Since he already has a ZC, he has already been converted from DPFI to MPFI. To run a b18 there are three wires that need to be added (knock sensor, o2 sensor, oil pressure sensor). Hasport makes a wire harness for these four wires for $75 (www.hasport.com) For B18 you will also have to get 90-93 integra axles and throttle cable and some different radiator hoses. A lot of good info at http://www.hasport.com. Hope this helps.
blackstar
12-19-2003 07:41 AM
blackstar
12-17-2003 06:03 PM
