vtec no workie for me!!!
Old Jun 25, 2002 | 12:19 PM
jg's Avatar
jg
Default vtec no workie for me!!!
So I unplugged the solenoid on my b20vtec for a some break-in driving, and upon plugging it back in it won't switch over to hi-cam(vtec lobe) now. I have 60~ psi of oil pressure and plenty of oil. Why? I've pulled the battery cables as well.
Old Jun 25, 2002 | 04:06 PM
Mikey3000's Avatar
Default Re: vtec no workie for me!!! (jg)
are you getting a CEL?
Old Jun 25, 2002 | 05:12 PM
Kamin's Avatar
Default Re: vtec no workie for me!!! (Boss Hogg)
https://honda-tech.com/zerothread?id=164863
Ok, I have noticed ALOT of people recently asking about why their vtec isn't working. I'm just going to do some of the basic steps in checking to see why the **** vtec isn't working .
1) Oil level, its gotta be FULL. I'm talking at the upper mark on the dipstick.
2) Solenoid, Ok this is a 2 parter. A) take a wire (any wire) disconnect the grey plug on the vtec solenoid and touch the wire to the pos. battery terminal and the solenoid side of the grey 1 pin connector. there should be an audible click from the solenoid. B) If A checks out, remove the solenoid and clean the filter screen. (self explanatory)
3) Speed, the car must be going over 10 mph so the spedo must be working. that means the VSS has to be working. vtec is temperamental isn't it?
4) more oil, check the oil pan. if its dented POUND IT OUT!. this is why mine wasn't working. the pan was dented in far enough to hit the oil pickup for the pump to cause low pressure situation in the head, no pressure no vtec.
5) ECU Swap out to another ECU that you KNOW vtec works on.
6) Car must be at I belive its 80 degrees or higher so let car get to a normal operating temprature.
7) If none of the above work, you might want to pull the solenoid off the head, remove the solenoid filter and verify the piston moves freely.
Thats a basic troubleshoot for it. if i missed anything or got anything wrong just reply and ill change the info.
If you go through all this and it still doesn't work its oil pressure (the pump) or wiring related. so check all the wires for vtec.
Thats it i hope it helps some people.
Joe
[Modified by KAMiN, 6:13 PM 6/25/2002]
Old Jun 25, 2002 | 05:22 PM
jg's Avatar
jg
no cel. I haven't tuned the car at all yet(breaking in after re-sleeving), and the cams have a less difference between hi and low lobes(proprietary(?!) Comp cams). Maybe I just can't feel it, but I thought i'd be able to hear it or feel it or something. I'll clean the solenoid/filter, and i'm also going to wire a small light bulb to the soleniod and see if that will tell me if it's working- I know-DORK!, and no I won't leave it there...
Thanks guys,
Jeff
Old Jun 25, 2002 | 06:12 PM
Malice's Avatar
New User
do you have a VAFC? u can check if its working with that if u can t feel anything
Old Jun 25, 2002 | 06:57 PM
Kamin's Avatar
Thanks guys,
Jeff
i wouldnt bother with the light bulb
just do the wire from the battery to the solenoid.
the light isnt gonna tell you much
if the light goes on but you dont feel it, then what? solenoid bad? your gonna need to check it with the wire anyway
good luck
and the light will test if the ecu is sending the signal to the solenoid to open it.
justinwazner
Nov 12, 2015 05:14 AM
Kamin
Feb 11, 2012 07:53 AM
EF_LSVtec
May 31, 2003 08:05 PM
tunes12
Oct 2, 2002 06:31 PM
Chuji
May 12, 2002 10:42 AM
