question about ls/vtec...
Old Jun 18, 2002 | 07:39 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default question about ls/vtec...
i read that you get "leakage"? i am considering building one...the only area that i can see that might leak is between the head and block because the gasket holes and openings don't seem to line up right. can anyone who knows, let me know about this leakage if there is and how bad it is? thanks.
Old Jun 18, 2002 | 07:53 AM
X2BOARD's Avatar
Default Re: question about ls/vtec... (not so civic)
There is no 'leakage' unless you screw something up. Doing an LSVT requires you plug an oil galley on the VTEc head since the LS block does not have the oil passages to supply the head (dowels are also modified). This is why you need to run an external oil line from the block to the head.
Done properly, an LSVT does not leak and if a shop tells you this... don't do it with them.
Old Jun 18, 2002 | 10:34 AM
Default Re: question about ls/vtec... (X2BOARD)
no shop ever touches my car or motor...i'll be building it. i was just curious because in a honda tuning or one magazine said "you'll have leakage". maybe it was super street and they suck. i didn't see how though and wondered why they stated that. but i know what's all involved with a proper lsvtec build. thanks for the input.
Old Jun 18, 2002 | 02:14 PM
Eyewitness's Avatar
<------Will NEVER believe what he reads in magazines
Old Jun 18, 2002 | 03:02 PM
sleeper4dr's Avatar
i completely agree. i just finished putting together my second ls/vtec motor this weekend and there are NO leaks. none at all.
thugsbryan
Engine Machining & Assembly
Sep 17, 2015 05:00 PM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
B16Civic93
Dec 27, 2004 04:20 AM
pulgaleakimports
Sep 14, 2004 02:06 PM
HybriDNA
Nov 12, 2003 10:35 AM
