b swap problems
Old Oct 7, 2012 | 11:58 AM
89EFhatchb18's Avatar
Icon2 b swap problems
Hey everyone im new on here but anyways ive been workin on this b18a1 swap into my EF hatch its been previously converted to obd1 and the motor was obd0 i put the injectors and dizzy and altenator on it but its bogging out and now it wont stay running im lucky if it'll even start im really getting frustrated with it idk if idont have something hooked up right but i would appreciate any help that can be offered
Old Oct 8, 2012 | 05:10 AM
meda215's Avatar
check it grounds first. trans to chassis, valve cover to chassis, thermostat ground. if still nothing check ur iac, take it off spray sum carb cleaner n let dry for a while, if its an a1 u should have a fitv under the throttle body. remove and disassemble. easy. then wen u reassemble tighten all the way down. let me kno how it goes.
Posted from Honda-tech.com App for Android
Old Oct 8, 2012 | 08:03 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: b swap problems
Car, year, make, model?
Which injectors and dizzy did you use, obd1 or obd0?
Which ECU?
Any check engine lights?
jdm ef9 hatch
Apr 18, 2010 02:38 PM
nickeynick
Jun 29, 2009 08:52 AM
xsi90teg
Feb 19, 2009 12:28 PM
one-cam
Sep 28, 2008 08:21 PM
Rukusmasta2
Feb 8, 2008 12:53 PM
