engine swap help
Old Oct 25, 2012 | 01:43 AM
jwatsoncrx91's Avatar
Default engine swap help
I am getting ready to swap a b18b into my 91 crx hf and was wondering what else I am gonna need for the swap
so far i have the b18b engine and I think it was a y80 tranmission out of a 97 teggy gs, also have the b series mounts. What else will I need? I have done some searching but everyone seems to be doing this swap in an si and cant find anything for the hf. also wondering what i will need to make the hydro transmission work for my car.
Old Oct 25, 2012 | 02:15 AM
crx_si-r's Avatar
Default Re: engine swap help
i can already see you haven't done any research. if you had, you would already have your answer. especially for this car
Old Oct 25, 2012 | 01:45 PM
theEFkid's Avatar
search is a wonderful thing, the info is out there
but just aa ball park, youll need shift linkage, hydro to cable conversion (personlly i have a 88 hf with an LS in it, and i prefer putting in a cable trans rather then converting to hydro, much simpler in my opinion, but to each his own) if your refering to the B series mounts as the one that came out of the teg, they wont work, you need B series swap mounts, also youll need to convert to OBD1, use an OBD1 ecu the factory one for that motor is a P75, and a OBD0-OBD1 jumper harness, plus all the little odds and ends
91civicsikid
Jun 13, 2008 05:14 AM
97EXCivicCP
Feb 2, 2006 06:40 PM
Moon Ill
Jun 16, 2005 04:23 AM
pushinlsteg
Dec 27, 2004 12:48 PM
theredegg
Jul 25, 2004 05:27 PM
