issue in starting b18c :( help needed
Old Oct 22, 2012 | 10:11 PM
uzi boy's Avatar
Default issue in starting b18c :( help needed
hi.. I hope all of you are fine..
well I need some help guys I got a civic & I swapped b18c type r engine in the last month
im facing 2 problems & as the winter is getting closer the 1st problem is getting worst & other is same as it was in summer
1 ) what problem im facing is that..when I start the vehicle after 6-12 hour or above it takes 2-4 ignition to start..once it starts..it all good the whole day by when I left it at night..then in the morning it got the same problem
I changed the plugs but the problem remained.. I changed the distributor but problem remained..
2) second problem is that ...when you are at last level of ignition like when the check light comes on then when it goes you start your car
when ever I let the check light turn off my vehicle always starts on second ignition no matter what I do.. even if the car is warmed up properly..
like if I start the vehicle without letting the check light turned off it starts immediately if the car is warm
help me with this problem guys im very tensed as its my 1st swap
WHAT CAN BE THE PROBLEM GUYS I NEED YOUR HELP...ANY ONE ELSE FACING THESE PROBLEMS..??
Old Oct 22, 2012 | 11:30 PM
jbpnoman's Avatar
Default Re: issue in starting b18c :( help needed
Get a fuel pressure testing kit. Strong chance on your fuel pump not sending enough pressure to the rail. 92-00 D series specs call for 36-40 PSI as tested at the filter. 99-00 B series specs call for 40-44 PSI. I'm fairly sure the B18C5 calls for even higher than that.
Old Oct 23, 2012 | 04:37 AM
uzi boy's Avatar
ill check it but fuel pump is new bro... its walbro 192LPH
Old Oct 23, 2012 | 10:05 AM
FrodeyEJ1's Avatar
im 99.2 percent positive its a fuel pump or some other fuel issue
my buddies car did the same thing even the deal with the CEL. replaced fuel pump and was good to go
Old Oct 23, 2012 | 10:16 AM
uzi boy's Avatar
well I give it a try with the new fuel pump
Old Oct 23, 2012 | 12:20 PM
EFinAwesome's Avatar
Just remember just because something looks new doesn't mean it works like new. Have gotten parts that had to be sent back before. Don't rule something out because you just bought it.
Old Oct 23, 2012 | 07:25 PM
uzi boy's Avatar
true that... today around 3pm ill let u know..right know going to university
uzi boy
Engine Management and Tuning
Oct 23, 2012 09:46 AM
uzi boy
Oct 22, 2012 05:00 PM
ClayM
Mar 9, 2004 07:47 PM
deviant94ex
Jan 2, 2002 05:30 PM
sebastianpr
Aug 24, 2001 07:41 PM
