95 civic h22 swap
95 civic h22 swap
Hey guys I just put a jdm h22 into my eg and im trying to find some good pics of how the shift linkage is routed. I hooked mine up already but the shifter feels sloppy and the cables look too loose under the car so I think I routed it wrong. I cant start the car right now to see how it drives because im waiting on a new balance shaft pulley to get here. If anyone can help it would be greatly appreciated. Thanks
Re: 95 civic h22 swap
Well when i did mine, i drilled 2 holes on shifter tunnel just ahead of the shifter (towards firewall) and just connected to trans and shifter. Looked a tad loose but not horrible. Post pics if u can of how you ran them
Here this might help some this is kinda what i did just not as close to the firewall
http://www.jdmshit.com/H22A_ShifterC...ifterHole2.jpg
Also i used accord (91 if i remeber corectly) they were tad shorter but dont quote me for sure its been 6yrs. I also never had sloppy(to me) or high rpm grind. Also look in the hybrid section i think here on ht there was a guy trying k series shifter box setup with h22.
FWIW i believe hybrid racing shifter box works with there h22 brackets and you use rsx/hybrid racing cables. much simpler/cleaner but more expensive solution.
