timingbelt issue b series
94 civic with a b17 block
So i have a few questions
1.which direction do i tighen? clockwise or counter?
2. which side to i put on first Intake or exhaust?
I tried tightening and it always slips off one cam.. I was looking around and i can't seem to find this anywhere
Yes I know where TDC is and its set, I just need the following either explained to me or in a picture..
Thanks in advance
Thanks in advance
Re: timingbelt issue b series
Why is there even a forum if your going to say that, i should just reply to that for anyone with a problem. I know it's in the book... I'm do my posting from my phone, so it doesn't do me any good to download it on my phone.
1) Remove the cylinder head cover.
2) Set the No. 1 piston at TDC
3) Rotate the crankshaft five to six revolutions to set the belt.
4) Set the No. 1 piston at TDC
5) Loosen the adjusting bolt 1/2 turn (180deg) only.
6) Rotate the crankshaft counterclockwise 3-teeth on the camshaft pulley.
7) Tighten the adjusting bolt to the specified torque.
8) After adjusting, retorque the crankshaft pulley bolt to 177Nm.
I believe this is correct, please let me know if its not.
RIP V8s
11-12-2007 11:28 PM
the.hamburglar
09-27-2005 03:26 AM
lsvtec101
03-18-2003 11:19 AM
