WHERE DOES THIS HOSE HOOK UP TO?
Old Sep 27, 2012 | 08:31 AM
jtac616's Avatar
Default WHERE DOES THIS HOSE HOOK UP TO?
where does the other end of this hose hook up to? its a b18c1 in a 97 dx
Old Sep 27, 2012 | 09:45 AM
bambam's Avatar
Default Re: WHERE DOES THIS HOSE HOOK UP TO?
That could either supply the FITV, or the IACV. It all depends on what combination of water pipe, coolant necks, intake manifold, throttle body you are using. The only real ones that are important are the IACV. If that is supplied, just plug it. That doesn't look like the standard B18C1 coolant neck anyway.
Old Sep 27, 2012 | 10:13 AM
lunatics209's Avatar
Plug it
Old Sep 29, 2012 | 02:52 AM
jtac616's Avatar
Plugged it but now im pouring coolant from underneath the car on the passenger side and i have no heat...i dont think this hose is even long enough to hook up to the heater core. Im stumped
Old Sep 29, 2012 | 04:31 AM
Jimmynitro's Avatar
Should go right on bottom of throttle body
Old Oct 1, 2012 | 07:14 AM
kyden's Avatar
it appears to go on the thermostat housing.
as far as no heat, make sure all the hoses are hooked up in their correct places.
Old Oct 9, 2012 | 10:50 AM
jtac616's Avatar
There is no nipple for it to hook up to on the thermo. Ive spent a week trying to figure this out
Old Oct 9, 2012 | 10:53 AM
jtac616's Avatar
I now have heat but still have this hose that hooks up to nowhere. When i plug it..colant pours from the bottom plastic hose thats connected to the charcoal canister
Old Oct 10, 2012 | 04:25 AM
silverhatch13's Avatar
So when you leave it unplugged, your saying it stops leaking and your heat comes back? just leave it then. could be just a breather tube or something.
Mr.Merz
14
Sep 5, 2016 07:53 PM
SolScifen
Jul 19, 2012 08:44 PM
I B BANGGIN
Aug 12, 2007 04:32 PM
81CB900C
11
Jul 11, 2007 04:19 PM
hotrod99
May 5, 2007 12:11 PM
