PLEASE HELP 2000 CIVIC ENGINE SWAP
Old Aug 23, 2012 | 08:16 AM
NCSHERO's Avatar
Icon2 PLEASE HELP 2000 CIVIC ENGINE SWAP
I HAVE A 2000 CIVIC OBD2B
Obd2a b18b engine,wire harness and ecu
Obd2b to a harness adapter
Odb2b wire harness
The engine already has harness on it obd2b
Do I need to leave it on or take it off
What elese needs to be changed?
Old Aug 23, 2012 | 08:41 AM
kyden's Avatar
Default Re: PLEASE HELP 2000 CIVIC ENGINE SWAP
obd2b to obd2a conversion harness. google it.
Old Aug 23, 2012 | 08:17 PM
hybridmiklo's Avatar
You dont even need to google. Search this hybrid forum. Its under "let cut down on repeated questions"
Old Aug 24, 2012 | 01:03 AM
HondaPartsHero's Avatar
Technical Hero
What trim is your Civic? EX, DX,CX,HX?
Old Aug 24, 2012 | 10:27 AM
NCSHERO's Avatar
i have looked at that half of the damn links dont work !!!!!!!!!!!!!!!!!!!!
Old Aug 24, 2012 | 10:29 AM
NCSHERO's Avatar
idk 2 door sunroof d16y8
Old Aug 24, 2012 | 10:57 AM
Technical Hero
You can't use the B18's harness. You'll want to use your harness but will have to make some adaptations:
-intake air temp sensor is different, use the one from the civic and put it in your intake arm
-distributor plug is different, you'll need to either use an adapter, swap internals, or cut and solder new plugs on it
Old Aug 24, 2012 | 10:58 AM
Technical Hero
He's right the links on the FAQ on this forum are beyond needing updating. Most of them don't work, pics don't work or are just plain bad.
BOOSTEd2
13
Mar 28, 2011 04:56 PM
D_koschak
Jan 21, 2011 05:46 PM
TwoKSiR
Dec 18, 2008 10:28 AM
EF7
Sep 25, 2006 09:06 AM
josh green
Jan 20, 2005 04:19 AM
