gsr swap help!
gsr swap help!
Alright guys im putting in a gsr into my 95 civic but ran into some problems:/ this is my first swap. i cnt plug n play with the harness becasue the the alternator,dizzy and fuel injectors are obd 2
So wat could i do? could i replace them with my d series dizzy alternator n fuel injectors??thanks!
Technical Hero
Re: gsr swap help!
Us your swap JDM or did it come with its harness?
1. For the injectors as long as your Civic was an EX/SI/DX you can use your injectors
2. For the alternator you can try this or solder on the OBD2 alternator plug
http://www.hamotorsports.com/obd2-al...1-harness.html
3. Distributor can just use an adapter or solder/swap the OBD1 connectors on your GSR distributor
Re: gsr swap help!
i just found out that the ahrness dsnt plug in with the speed sensor:/ what could i do now? do i have to buy a obd1 sensor or could i use my d series one?
chrisc543
02-19-2014 07:22 PM
vtec25
10-09-2005 05:49 PM
