H22 swap, No vtec after service.
I have a 98 ex with a JDM H22a swap.
The timing belt tensioner was starting to make noise so I changed everything while in there.
I replaced both tensioners and pullies and water pump.
I also replaced the valve cover gasket set, pcv and pcv grommet.
While I was working on it I installed my Mishimoto radiator also.
After completing I bled the coolant system, reset base idle and timing( was off before).
The car idles and runs out great, has excellent response but vtec is not kicking in.
Any ideas?
Thanks
Dayton
Any ideas?
Thanks
Dayton
Re: H22 swap, No vtec after service.
Is car actually reaching operating temp? If not this can affect vtec operation any check engine lights? And double check all connectors to make sure you didn't push a pin out,and that all connectors are plugged in properly.
Not really sure what it was,
Must of still had a air pocket as it took quite a bit to top the coolant off after yesterdays drive.
I checked all the connections and made sure it was up to full temp.
Pulls like mad again,vtec working as it should.
Thanks
Dayton
Thanks
Dayton
jdmej814
12
03-16-2009 11:44 AM
Random.Hero
09-13-2007 07:56 PM
jdmaccordh22
03-19-2003 10:00 AM
