Which B20 makes better power non-vtec and n/a?
B20z 9.6cr
B20b 9.2cr with P8r head
I'm looking to swap into my 1997 Civic pretty soon but I haven't exactly found a convincing answer to which is better during my search. All indicators say go with the 9.2cr because the P8r head flows better but I'm not sure if the better flowing head is that great of an advantage over the higher compression ratio.
Please inform.
Thanks,
Jason
Please inform.
Thanks,
Jason
Re: Which B20 makes better power non-vtec and n/a?
I've done quite a bit of reading only to find more questions really. Here is a couple of links that I refound from my reading last night.
https://honda-tech.com/forums/tech-misc-15/jdm-b20b-p8r-3055775/
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/b20-p8r-cams-vs-p75-cams-2922017/
http://98.158.194.248/showthread.php?t=3042761
Buying the 9.6cr b20 and adding the p8r head is out of the question because this is going to be a low budget swap. But buying the 9.2cr engine with the p8r head is an option if it's the better engine once I start adding the intake manifold and exhaust.
Check the last comment on this post.
http://www.clubcivic.com/board/sitem.../t-205845.html
Now you may see why I'm confused.
