Engine Harness Question
Old Aug 24, 2012 | 04:05 PM
Joacnel's Avatar
Default Engine Harness Question
Can I use my '00 Civic DX engine harness with my LSV?
Old Aug 24, 2012 | 04:21 PM
JuggerNaut-CTR's Avatar
Default Re: Engine Harness Question
Is the motor going to be obd2b?
If so, a 99-00 ex manual harness would be a lot easier to deal w/ than a dx. You're still going to be a doing a little wiring, using the ex harness means you will only have to cut and lengthen a few connectors so that they reach their respective sensors.
Old Aug 24, 2012 | 07:30 PM
Joacnel's Avatar
I'm a noob when it comes to the obd2a and obd2b. But he'a both the car and the engin (LSV) are obd2 and I'm trying to stick with it. I've heard the ex one was a lot faster to deal with but its kinda tough finding one unless I go on rywire :/. I wanted to see if also anyone knew if there was a way to use my dx's harness to plug into that engine and what modifications to it I'd have to do along with what I'd have to do about the drivers side firewall plug. This is my first swap so I didn't wanna mess it up.
Old Aug 25, 2012 | 03:53 AM
HondaPartsHero's Avatar
Technical Hero
You can use it it with modifications.
-IACV convert to 2 wire
-distributor adapter, obd2b to obd2a
-use your DX intake air temp sensor
-extend 02 sensor
-wire up VTEC and knock sensor
allanjr350
10
Jul 2, 2015 08:26 PM
ordny6
Apr 19, 2008 07:27 AM
Slick2126
Apr 2, 2006 05:03 AM
SOHC_Brian
Dec 5, 2003 09:07 AM
SC61HB
Jan 27, 2003 01:56 PM
