Helpp!! How to make usdm obd1 gsr. Vtec crack using usdm obd2 ecu
Just need some help to make my car crack vtec it runs fine never tried to.crack vtec cuz still breaking in but I did alot of readin ppl say it wont crack using a obd2 p72 ecu on my obd1 motor is that true??
Re: Helpp!! How to make usdm obd1 gsr. Vtec crack using usdm obd2 ecu
WTH are to trying to ask exactly?
1) If you have an jumper harness and everything is wired correctly there is no reason vtec should not engage.
2) It takes 3 hours max to break in a motor properly (including oil changes and cool down cycles). Man up and put your right foot down. Even then you should be able to get vtec to engage without going full throttle.
3) The more you bump a thread the less people are going to want to help.
Vero
06-16-2007 03:41 PM
