01 h22a4 swap in 99 Civic ek coupe
hi i an new here hope this is in the right place i have an 01 h22a4 i am trying to put in my 99 ek i have all the motor mount and axle set up i am trying to figure out how to wire it i have a 94 p28(idk if it is chipped or not). so here is the deal i have the wires for under the hood and was told it is easier to run it obd1 the wire harness in side the civic did not plug into the p28. so do i need to get another harness that plug my harness under the hood to the p28 and how do i wire the civic wires to the p28 thanks hope this is not to long
Re: 01 h22a4 swap in 99 Civic ek coupe
you use your civic harness and extend the wires an needed you will have wire in a resistor box in for the injectors re wire the alternator connector to the h22 and you will need a obd2b jumper harness in order to plug to the p28
I do don't have Civic one I guess I will have to get one from a junkyard and you can you explain to me how to have to attach the both of them
