need help in central jersey area
Old Feb 1, 2004 | 02:27 PM
integra6650's Avatar
Default need help in central jersey area
i had a 99 gsr so ipulled motor and put it in a 94 dx. when i started wiring i bought obd1 gsr wires all the way up into the dash(so thats engine, main interior, and dash). my problem is i have a bunch of extra harnesses that i dont know where they go. if anyone in the area can give me a hand let me know i really want to get this project done. Imptuner@comcast.net
Old Feb 1, 2004 | 08:46 PM
4crx4me's Avatar
Default Re: need help in central jersey area (integra6650)
I'm not sure I understand what you're asking.
Could you clarify it a little more.
Old Feb 2, 2004 | 03:59 AM
97civicdx's Avatar
5th gen civics should just be a plug in with the engine harness of the GSR motor. Did the engine harness come intact and still plugged into the motor?
Old Feb 2, 2004 | 05:41 AM
Default Re: need help in central jersey area (97civicdx)
it was my 99 gsr motor i bought all obd1 GSR harnesses to match my aem and internal harnesses. didint work so i replaced interior harnesses with obd1 gsr
Old Feb 3, 2004 | 07:27 AM
all plugged in or eliminated except for 3 things.
theres a Brown harness with 1 plug in it thats Blue with red stripe its off the main interior harness
theres the brake sensor cant find harness for it
theres 2 harnesses cant find for the stearing column but its an 0bd2 steering column 1 i believe is for the imobilizer its 4 or 5 wire green harness, and the other is a 2 wire whiteone on bottom of column
i believe thats it im not getting any starter. if my aem werent programed correctly could that prevent the starter from starting? or could it be the imobilizer
Old Feb 4, 2004 | 04:58 AM
the main problem is right now the starter isnt starting on ign 3 so im gonna make a remote start to check stater
Old Feb 4, 2004 | 07:45 PM
got it started the aem was programed wrong i plugged in a 94 dx ecu and it fired up like a champ
deguzmanEG
Jul 1, 2012 12:46 PM
Maui Built
Northern California (Sales)
Jun 16, 2008 08:47 PM
ek_b16
May 7, 2008 08:06 PM
saleensolution
Oct 25, 2005 04:42 PM
