how do i run my msd rpm activated switch
i have a single vtec motor in my 89 civic si and i got the msd rpm activated switch how do i run that to make vtec work and can some one tell me what color wire does the white from my msd go to on my distributor
Modified by racingant at 6:37 AM 1/24/2004
Re: how do i run my msd rpm activated switch (racingant)
run the vtec solonoid to msd switch's positive output. hook up the positive and negative to ur battery then u should have tach wire to hook up. u hook the tach wire to the tach wire on ur ecu harness. i would get an oil pressure gauge tho so ur not hittin vtec with no oil. good way to blow ur engine.
you can hook the white wire to negative side of the coil, yellow wire goes to vtec, black wire you ground out anywhere on your body and the red wire you can hook to a switched positive, or right to the battery. it shouldnt hurt it to keep it on all the time however it wouldnt be pretty easy to hook it up behind your radio, and hook the ignition wire on the radio to the red wire on the rpm activated switch.
quick chart if u dont wanna read my post
Red - ignition wire on back of radio
Black - ground
White - negative side of your coil, you have to pull ur cap off the distributer to check which color wire it is coming out of the dizzy.
Yellow - run to vtec solonoid
Grey - not used
Black - ground
Grey - not used
no, the msd switch has a relay in it. it says how many amps it is capable of in the instructions i forget how many tho. you def dont need a relay tho.
vegaskurt
10-04-2005 01:29 PM
JSPECHB
02-17-2004 02:30 PM
racingant
01-11-2004 05:15 PM
activated, activation, civic, honda, install, instructions, manual, msd, problem, rpm, rpmactivated, si, switch, vtec, wire
