94-00 GSR motor mounts and axles
Re: 94-00 GSR motor mounts and axles (Austinbionic316)
You might come across some used ones, but chances are you'll need to order the mounts directly from Honda/Acura. The axles you can get at any Autozone, Pepboys, Napa and places like that.
you can get axles and mounts from a lot of aftermarket sources... http://www.hasport.com , http://www.jdmshit.com , etc but also salvage yards like http://www.importautosalvage.com among others.
there are plenty of dudes online here selling that stuff in the classifieds.
for a 96+ Civic make sure you use the correct rear bracket, that goes on the trannt/block to the firewall mount. this part is different from integras and 92-95 civics! it is commonly called an EK or 99-00 Si rear mount.
VTecLude1994
07-26-2005 01:56 PM
