b16a2 into 95 dx EJ coupe how to keep a/c
I am trying to find out what mods need to be done in order to keep a/c when swapping the b16a2 into a 95 dx coupe. So far it seems that i need to get an a/c bracket from a del sol vtec. Has anyone done this? have pics?
Thanks
Thanks
Re: b16a2 into 95 dx EJ coupe how to keep a/c (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">p54 ac bracket from the del slow is ALL you need, bolts up from there and ur good 2 go </TD></TR></TABLE>
good luck with the swap and make sure you have all the other mounts needed too
Re: b16a2 into 95 dx EJ coupe how to keep a/c (hyperdecalsdotcom)
I am having problems finding where to get the p54 ac bracket? anyone have an idea of an average price range? is this the small bracket that is like 5 bucks or is it something that goes for like 100? thanks for all the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyperdecalsdotcom »</TD></TR><TR><TD CLASS="quote">for the engine/trans mounts, dont i mix my stock ones with the jdm b16a2??</TD></TR></TABLE>
no, you'll want b-series mounts. Either del sol vtec, or integra mounts
And the bracket...
Like we said, all you need is this and everything else will bolt on .</TD></TR></TABLE>
right click .. save as great diagram buy everything you see there and the swap will be cake! a/c mount usually runs about $100, call honda heaven if you can't find one, they usually have a couple http://www.h-heaven.com for info
And the bracket...
hmtcrxsir
21
07-29-2013 10:31 AM
Conviction
03-12-2004 06:47 PM
