Need some advice
Old Jan 29, 2004 | 05:52 AM
genop's Avatar
Default Need some advice
Ok, I have posted about this before but now I have some new questions. First of all, I just got done putting a d16z6 into my 97' civic (d16y7 nonvtec). I had to replace the drivers side mount, but so far everything else has lined up good *knock on wood* I also bought an obd2-1 converion harness and a p28 ecu to use with this. Some of the plugs on my y7 harness dont plug into the sensors on the z6, so I found a z6 harness to use but here is the real question. Should I just splice the connectors into my y7 harness or try to use the entire z6 harness? It would seem easier to just splice in the connectors that wont fit, but I figured I should ask.
Also, since I have a y7 it wasnt wired for vtec, what wires do I need to run to make vtec work?
Thanx!!
Old Jan 29, 2004 | 07:48 AM
genop's Avatar
Default Re: Need some advice (genop)
anyone?
Yomage_EG
Sep 24, 2013 11:26 AM
AlfieRoach
Nov 14, 2010 12:02 AM
lilo_goki
16
Aug 4, 2007 03:20 AM
coreypoppej6
May 15, 2005 11:52 AM
Jeff_G
Sep 8, 2002 04:48 AM
