P30 ECU... Looking for heater in O2 Sensor?
Old 02-07-2004, 05:36 AM
JDMB16EG's Avatar
Default P30 ECU... Looking for heater in O2 Sensor?
I am just completing a swap with a 1st gen (88-91) B16A into an EG hatch. It is on the road and running fine. But, the check engine light is still on. It is giving a code that is telling me that there is a heater missing in the O2 sensor. I know it doesn't need one, but how can I make the ECU think that it has a heater in the O2 sensor just so the damn check engine light will turn off. How can I override the system to do this??
Old 02-09-2004, 10:38 PM
Qfactor's Avatar
Default Re: P30 ECU... Looking for heater in O2 Sensor? (JDMB16EG)
use a 5-10 watt 30-40 ohm ceramic resistor to simulate the resistance of the heater element. make sure is not touching anything that would catch fire. might want to get a small heat sink or get a higher wattage like 10watts but not less than Watts.
Old 02-10-2004, 03:55 AM
VTECVillain's Avatar
You shouldn't have to "fool" the ECU because if the O2 is good and it's wired properly then it will not throw the CEL. The heater element is part of the 4 wire O2 which you must use a 4 wire O2 sensor with a P30 ECU. If you have a CX or VX model then you need to convert the wiring to a 4 wire O2 setup.
Old 02-10-2004, 07:09 PM
Qfactor's Avatar
Default Re: P30 ECU... Looking for heater in O2 Sensor? (VTECVillain)
The part of the O2 sensor will still work sending its signal to maintain proper air/fuel mixture, I've tested O2 signals with an O-scope that had bad heater elements and these O2's where from obd2 vehicles with less than 25k on them and work flawlessly.
Old 02-11-2004, 06:51 AM
stevel's Avatar
Default Re: P30 ECU... Looking for heater in O2 Sensor? (Qfactor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor &raquo;</TD></TR><TR><TD CLASS="quote">The part of the O2 sensor will still work sending its signal to maintain proper air/fuel mixture, I've tested O2 signals with an O-scope that had bad heater elements and these O2's where from obd2 vehicles with less than 25k on them and work flawlessly. </TD></TR></TABLE>
yeah, it will read a/f fine, once it gets hot. O2 sensors aren't very effective when they are cold. Might not be a big deal if you're in a warm climate but during cold start the car might run like crap til the sensor warms up from the engine, which could take a while. For the $55 it costs for a new sensor just get a new one instead of rigging in a resistor.
s
Old 02-11-2004, 08:52 PM
Qfactor's Avatar
Default Re: P30 ECU... Looking for heater in O2 Sensor? (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">
s </TD></TR></TABLE>
Damn, $55 dollars I hope it's not cheap Bosch O2 sensor, that would be good for about a year.
Old 02-12-2004, 04:53 AM
stevel's Avatar
Damn, $55 dollars I hope it's not cheap Bosch O2 sensor, that would be good for about a year. </TD></TR></TABLE>
Bosch is one of the better names out there when it comes to OE equipment. I've never had any problems with them. I think the dealer price for them is insane.
s
Old 02-12-2004, 09:42 AM
JDMB16EG's Avatar
i decided to switch to 4 wire instead of ghetto rigging it. The dealer price is like $275. INSANE is right. I can't find a $55 one, but i found one for $117. Good enough for me. Thanks for everyone's help.
racingant
12
11-11-2005 06:41 PM
92CiviCJdMMX
02-04-2004 11:38 PM
gtpilot
12-12-2002 12:27 PM
gsr stuie
05-01-2002 10:18 AM
hecktabite
04-28-2002 10:14 PM
Quick Reply: P30 ECU... Looking for heater in O2 Sensor?
