Very Weird Swap, Need Help
Hey everyone. I own a 1993 Acura Vigor GS 5-Speed and am interested in doing a motor swap. I love my G25A1 I-5, it's got decent pickup and runs fine but the problem is it has absoultely no aftermarket support whatsoever.
Supposedly this car is "unswappable" but I'll believe it when I see it, if there's a will there's a way. The engine is mounted North South and it's FWD, so that right there should give you some idea on how much of a pain in the ***** this might be.
My goal is to do an H22A4 turbo, and I know this would require a fair amount of fabrication, but I am hellbent on doing this.
What kind of obstacles would I be facing in doing a swap like this? I know motor mounts is obviously one.
Please don't try to deter me from doing this, it's too late now.
TIA
TIA
Re: Very Weird Swap, Need Help (AcuraFanatic)
I'm glad to see someone is straying from the beaten path for once. But, don't get me wrong this swap will be a real bitch. Getting axles that will fit will be hard. You'll have to have them made. Same with wiring, which is ALWAYS a problem. Hope you have a mechanic who knows what he's talking about when it comes to swaps. Good luck, and may the force be with you.
Vigor is on it's own platform as far as I know. I rather do an H22 instead of a F20C (S2000 motor). It's just too damned expensive. Plus it's nice having more useable torque in such a heavy car (~3150 pounds).
Like I said I imagine just a swap of a stock H22 wouldn't make it much quicker (top end only) but the potential the motor is what I'm interested in.
Does your stock vigor engine turn clockwise like the new K-series engines or counter-clockwise like the B-series and H-series engines?
Re: Very Weird Swap, Need Help (keithg)
you might want to look into some sort of tranny adaptor plate and just stick the h22 in there the same direction as the 5 cyl is, if it spins the same way.
Re: Very Weird Swap, Need Help (jweller)
I was thinking of mounting it North South, it'd make my life a lot easier. Plus that's the correct way motors should be mounted anyhow.
Streetballer4888
Honda Civic (2001 - 2005)
13
04-26-2007 09:19 AM
XcLuSiVeLy4GoD
09-06-2006 04:48 PM
