B16B Water Pump Question
I'm looking to buy a CTR engine from Total-Boost in the near future. I know that once I get the engine I have to do some basic maintenance, i.e. compression check, leak down test, change timing belt, water pump, belt tensioner replacement, clutch (clutch kit) replacement, not to mention the fluids and some other things. Enough babble, what I need to know is which water pump will I need since the CTR is not sold in the States, but it's the same block as the ITR. Any information on this subject would be appreciated. Thanks!
krazie 1;
Just trying to put a little security into the project, that's all
. Thanks for the reply brother.
B-series Water pumps are pretty much the same BESIDES that Vtec water pumps have more teeth on the pulley and less (shorter) propeller teeth. So you need a Vtec B-series (GSR/ITR, does not matter) water pump.
