2000 gsr motor in 92 civic si
wassup yall, im just wondering if theres anything i have to change or do for wireing when i swap a 2000 gsr motor into my 92 civic si, is the 2000 gsr obd2 or obd3, and how does it affect to swap into an obd1 car, thanks, need to know the info asap
Re: 2000 gsr motor in 92 civic si (myhatchrips)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips »</TD></TR><TR><TD CLASS="quote">obd 1 conversion</TD></TR></TABLE>
That's ridiculous, there is no need to convert to OBD1. You can drop the complete 2000 GSR motor into the 92 Si and simply use an OBD1 P72 ECU. The USDM OBD2 Integra engine harness will plug up to the shock tower chassis plugs and everything will be plug and play. Since the car is already wired for VTEC and a 4 wire O2, all you will need to do is add wiring for the knock sensor and IAB.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips »</TD></TR><TR><TD CLASS="quote">well eventually you're going to want to switch over to obd-1. </TD></TR></TABLE>
Why you want to switch over OBDI since VTECVillain already said to use an OBDI P72 ECU? The whole purpose of running OBDI is just for the simplicity of chipping the ECU.
There is no point in changing the motor's components to the older OBD1 style, you don't need to at the time of the install and you won't need to anytime after. The good thing about EG's is the fact that you can run a complete OBD2 motor and simply use an OBD1 ECU. This makes it easier to get a newer engine with less miles and still get the performance of an OBD1 setup by using the OBD1 ECU and not needing an ECU adapter.
Re: 2000 gsr motor in 92 civic si (1993sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir »</TD></TR><TR><TD CLASS="quote">im not sure if it goes for gsr, but for a 2000 2001 type R into an eg you will have to run a wire from the distributor to the driver side engine harness plug before it goes to the fire wall for the tach to work. </TD></TR></TABLE>
There is another wire on the drivers side that you can tap without going through the dizzy
Re: 2000 gsr motor in 92 civic si (Touch)
i have a 0o type r harness in my eg. for the tach u have to tap in to the blue wire from the dizzy and connect it to the blue wire on the driver side shock tower. connecting from the shock tower is just so u don't have to run it to the back of the guage cluster.
the obd 2 dizzy it self has a black/yellow stripe power wire and a all blue negative from it but the engine harness from obd2 only has a wire connecting to the black/yellow wire. so u have to run a link
I hate people that give other people the wrong info.
Re: 2000 gsr motor in 92 civic si (Jun)
i wasnt giving him the wrong info. im just stating the fact that running obd 1 gives you more tuning flexibility compared to obd-2. sorry for the misunderstanding guys.
Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">VTECVillain....never forget the mind numbing powers of the beings known as 'newbians'.</TD></TR></TABLE>
Yes (sigh sigh) I know...
Re: (myhatchrips)
or u can use a chipped p28 and skunk2 mannie, the only wire you would have to run is the blue wire from your driver side strut tower to the blue wire on the distributor, if you have a stock tach. did this swap about a month ago, everything is plug and play, easy swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jun »</TD></TR><TR><TD CLASS="quote">I hate people that give other people the wrong info.
Werd. OBD-2 and OBD-1 = same electronics, same ****. Just differnet plugs on the motor, but like others already said, the GSR engine harness will plug into the EG shock tower plugs. The use of an OBD-1 ECU will plug right in, as well as not look for the additional sensors such as crank angle sensor and 2nd O2 sensor. I don't know how often I have to say OBD-2 and OBD-1 electronics are the same thing.... OBD-2 computers just look for additional sensors and there's just different plugs between OBD-2 & 1.
80 dolla crx hf
11-30-2009 11:57 AM
K i l l a B e e.
07-29-2009 08:30 AM
2gen_tegs_rule
09-22-2008 04:24 PM
