D to D series
Old Feb 2, 2004 | 02:30 PM
Dyzee's Avatar
Default D to D series
Hey guys,
I've searched and all that wonderful stuff but im just making sure I have everything in check before i go ahead and do this since i've heard mixed multiple answers to some questions. I'm going to be swap'ing my D15B7 to a D16Z6(No i dont have the money for a B/H series, and I'm going to be turbo'ing this D16 on about 8PSI...i picked up the D16Z6 engine/tranny for cheap) Oh..its an auto-manual swap AND an engine swap at the same time.
So heres my parts list:
Engine
Transmission (clutch, flywheel and all that fun stuff is in there)
Linkage/Stabilizer/Shifter Assembly
Pedal assembly
Computer(ECU)
Manual Starter
Hydrolic Lines
Now the only thing i have a question about is the mount(tranny mount). Ive heard mixed answers about this so i just need one final correct answer. I'm going to need the manual tranny top passenger side mount correct? If its something else let me know. Now, when i take out my AUTO mount, do i need to weld in this new manual mount or does it just bolt into factory locations? This is the only thing thats scaring me here.
Old Feb 2, 2004 | 03:11 PM
Turbogixxer's Avatar
Default Re: D to D series (Dyzee)
Yes, or you can get a custom mount from HCP or Place Racing.
Old Feb 2, 2004 | 04:01 PM
Dyzee's Avatar
I dont have the money for a custom mount so the manual tranny mount shall do.
So does it weld in or bolt up? (The manual mount)
Old Feb 2, 2004 | 06:32 PM
Default Re: (Dyzee)
you have to take the top trans bracket (drill the spot welds out) and weld it in to the auto car (you have to remove the old auto bracket first)
Old Feb 2, 2004 | 07:18 PM
B18bEK's Avatar
Default Re: (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">you have to take the top trans bracket (drill the spot welds out) and weld it in to the auto car (you have to remove the old auto bracket first)</TD></TR></TABLE>
i have heard mixed reviews on this .. some people who do this it works out fine .. others have done this and the the mount doesn't hold and rips off i'd wait and spend the money on the custom mount and do it right. but then again - thats just me place racing makes one for a reasonable price i believe
Old Feb 2, 2004 | 07:26 PM
Dyzee's Avatar
Its something like 150$ US. Sure that dosnt sound like much...BUT make that canadian, add taxes, broker fees and all of that and its an easy 300$ for a mount. I cant afford it.
Old Feb 2, 2004 | 07:42 PM
B18bEK's Avatar
Default Re: (Dyzee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyzee &raquo;</TD></TR><TR><TD CLASS="quote">Its something like 150$ US. Sure that dosnt sound like much...BUT make that canadian, add taxes, broker fees and all of that and its an easy 300$ for a mount. I cant afford it.
hehe. find a fellow h-t'er, paypal money .. only 3% have them get the product, then ship it to you as a private party. not sure if that helps you bypass any of those fees but its an option.
Old Feb 2, 2004 | 07:49 PM
Default Re: (B18bEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">
i have heard mixed reviews on this .. some people who do this it works out fine .. others have done this and the the mount doesn't hold and rips off i'd wait and spend the money on the custom mount and do it right. but then again - thats just me place racing makes one for a reasonable price i believe</TD></TR></TABLE>
I have only seen it fail when the installer is at fault.
Old Feb 3, 2004 | 04:32 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">I have only seen it fail when the installer is at fault. </TD></TR></TABLE>
Same here. If it's welded properly in the right location there should be no reason why it wouldn't be just like a stock manual equipped car.
Old Feb 3, 2004 | 03:35 PM
Dyzee's Avatar
Ok so just to wrap up.
1. Get the manual tranny mount
2. Get the manual tranny bracket (top)
3. Remove auto bracket
4. Drill spot welds out
5. Weld Manual bracket onto car.
Sound about right?
Old Feb 3, 2004 | 03:41 PM
Default Re: (Dyzee)
flip #3 and 4, you have to drill the spot welds out of both to remove them
Old Feb 3, 2004 | 05:17 PM
Dyzee's Avatar
Thanks alot man!
One final stupid question. All D-series mounts are the same correct? I can reuse my D15B7 engine mounts with the D16Z6? (IM geussing yes but im making sure before my car goes down for a while )
Old Feb 4, 2004 | 06:17 AM
Default Re: (Dyzee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyzee &raquo;</TD></TR><TR><TD CLASS="quote">All D-series mounts are the same correct?</TD></TR></TABLE>
Yes but only within the specific generations. Ex: 1990 D16A6 driver's side mount is not interchangeable with a 1999 D16Y8 mount. As long as you stay within the same generation you're good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I can reuse my D15B7 engine mounts with the D16Z6? (IM geussing yes but im making sure before my car goes down for a while )</TD></TR></TABLE>
Yes you can.
Old Feb 4, 2004 | 07:22 PM
Dyzee's Avatar
Default Re: (VTECVillain)
Thanks guys
Lots of great help!
JGTW
Dec 17, 2018 03:12 PM
Yonick90
12
Feb 5, 2010 06:26 AM
97civicdx
Dec 29, 2006 12:10 PM
El Ban
Aug 25, 2006 11:52 AM
kin6david
Jan 13, 2004 12:10 AM
