89 hatch with a b18c1 obd1
Old 02-02-2004, 08:03 AM
fffrog's Avatar
Default 89 hatch with a b18c1 obd1
Im doing a obd1 conversion and i also have to do the mpfi conversion. My question is since it is obd1 do i still have to get a resistor box and wire that in?
Old 02-02-2004, 11:51 AM
Crazy Honda Guy
Deetz's Avatar
You have 2 options:
1) keep your non obd injectors and resistor box
2)use the newer OBD1 injectors, but remove the resistor
Old 02-02-2004, 11:55 AM
fffrog's Avatar
Default Re: (Deetz)
I plan to use the obd1 injectors. So i take out the resistor box. Is it just one wire to each injector? also what about the power to the injectors?
Old 02-02-2004, 09:13 PM
hybrid_KJ's Avatar
Default Re: (fffrog)
wire in the obd1 injector clips. Take the obd0 injector resistor plug and repin the wires into an obd1 power distribution plug (8 wire plug with a cap on the end). This isall that is needed to delete the resistor box.
Old 02-03-2004, 01:55 PM
Jeff C's Avatar
There are 5 wires at the resistor box, 1 yellow and 4 red (I believe). Cut all five at the plug and solder them all together. When you put the obd1 clips on, just cut and splice near the clips.
Old 02-03-2004, 04:10 PM
fffrog's Avatar
Default Re: (Jeff C)
My car is dual point. there is no resistor box now. i think i just take the yellow/black from the chasis harness and wire all the yellow/black injector wires to that. does that sound right. thanks for all the help
beansandrice
33
09-08-2009 04:18 PM
88todab16crx
10-05-2008 05:22 PM
SupraRXZ
02-05-2006 06:57 PM
daidilus
45
02-09-2005 09:18 AM
JDMCivicEF9
19
09-06-2003 11:00 AM
Quick Reply: 89 hatch with a b18c1 obd1
