need help!! car won't start on b16a
well I thought my altenalter was bad and put a new one but it still not cranking, every time I jump start it it crank but u see the voltage gauge goin down quick and it was runnin.
Re: need help!! car won't start on b16a (dahveed)
Dude, we're gonna need like WAY more information. Check your grounds and make sure its all wired up correctly.
Like, what sound does it make if you try and start it
What voltage gauge?
Does it just die?
Does it ever start?
What voltage gauge?
Does it just die?
Does it ever start?
Re: need help!! car won't start on b16a (Devlins 91LS)
what happen was i driving on the road and suddenly the car stopped. i try jump starting it but it didn't work so i putted another battery in and it started but for about ten minutes later the car cut off so i tried jump starting it again but what would happen is the volt gauge in my car would say 12 volt but when we removed the cable it would lose power so the following day i install another alternator from a friends b16 but it still ate the battery. Today i put a new battery in and it crank but it still not charging.
NiKKa NiKKy
06-30-2022 09:59 PM
